Engine Oil usage
Old May 1, 2017 | 07:57 PM
  #41
splattttttt's Avatar
splattttttt
This is comferting to know... Looks like I had been doin it correctly all along. Yey me (:
And: is
"S&S Cycle, Inc. in town driving is not the same as Highway driving, (which
is where the most damage can be done). the occasionally town ridding, i can see and would accept the 2,000/2,500 rpm. It's the highway pulling the big gears, lugging that is so damaging. the amount of time spent at this RPM while lugging the motor is the smoking gun, so to speak."
Old May 1, 2017 | 08:02 PM
  #42
perki48's Avatar
perki48
Quote Splattttttt "my Slim's happy face is between 2,400 and 28,000,
Anywhere above that feels like I'm in a race"
28,000 would seem like racing to me also>>>>>>>LOL
Old May 1, 2017 | 08:05 PM
  #43
SamStone's Avatar
SamStone
Over 60,000 miles on my Road King. I have never had to add oil between oil changes. I never use synthetic.
Old May 1, 2017 | 08:09 PM
  #44
splattttttt
X use the typo perki. Do that often lol
but in and around town, ruizin at 2,800 seemed wacked
on the freeway, I'm there easily
Old May 2, 2017 | 05:03 AM
  #45
Warp Factor's Avatar
Warp Factor
Originally Posted by bikerlaw
Ok, I must say I am baffled that people don't know that lugging a Harley V-Twin is harmful to the engine....... but:...
...Here are quotes as to not muddy the waters, these came from S&S Cycle. At least in my opinion, there is no higher authority.
The S&S recommendations are probably the safest position for them to take, since many of their engines are high-compression, and they may go into everything from motorcycles without modern computer controls or detonation sensors, to motorcycles where the original detonation sensing ignition will no longer be effective, due to the engine configuration being different from stock. So these engines may be much more susceptible to detonation with high load/low rpm operation. It's detonation that's the real killer.
Let's take a closer look at one of their quotes:
"Lugging an engine means putting the engine under an extremely stressful load. Lugging causes extreme stress between the rear thrust faces of each piston and the cylinder walls. Small bits of piston skirt can break away causing the rear surface to scuff. The best prevention for lugging an engine (either old or new) is to downshift to a lower gear where the engine runs more freely, and the transmission assists the engine in delivering peak power to the rear wheel."
What they're describing is characteristic of detonation damage. If detonation is taken out of the picture, internal stresses are not greater at low rpm. In fact, rotational and reciprocating stresses increase as rpms rise.
The other major factor with engine stress is the cylinder pressure achieved during combustion. Again, this is not highest at very low rpm, but is highest right around the torque peak, say around 3000 to 3500 rpm on our engines. The exception is when detonation or pre-ignition are present, which can produce cylinder pressure spikes many times higher than normal. These pressure (and heat) spikes can produce anything from piston or cylinder wall scoring, to bottom end damage. A graph showing these pressure spikes, compared to normal combustion, is below:
Old May 2, 2017 | 06:03 AM
  #46
splattttttt
All goo points Warp
Old May 2, 2017 | 07:41 AM
  #47
bikerlaw's Avatar
bikerlaw
I don't know what to tell yah Warp. Your a smart guy, and ALWAYS post intelligent and useful posts. But if S&S Cycle...... the absolute highest authority on the planet, in terms of Harley Davidson engines and performance, says that lugging a Harley V-Twin engine is BAD. Trying to find a way to prove that is isn't and they are wrong, seems very self defeating. I choose to keep my engines above 2500 while cruising. But that's just me.
Oh, and I always run premium fuel. Because I really do think detonation is a hidden killer of motors. Lots of people think if they can't hear it, it isn't there. I disagree with that whole heartedly, and do everything to ward it, and of course lugging, off.
Old May 2, 2017 | 07:54 AM
  #48
Warp Factor
Well, I appreciate your patience and politeness, and willingness to at least consider other explanations.
Getting back to the 650 horsepower supercharged Corvette: GM will warranty these engines, even if the vehicles are used only for racing. The main reason they can get away with this is that the factory computer control system is so sophisticated, that these engines almost can't hurt themselves. But make any modifications (including tuning) to this control system, and your warranty has gone out the window.
Being an aftermarket supplier, I doubt that S&S has any where near that level of control over the wide variety of conditions under which their engines will be operated, or who will be tuning them. So it makes sense that they would "play it safe" with their recommendations.
Old May 2, 2017 | 08:37 AM
  #49
splattttttt
BikerLaw, I didn't think Warp was calling S&S liers. He simply stated they're covering their own by warning against lugging.
but whyle we're here, what is worse? Lugging or detonation
what causes detonation?
Old May 2, 2017 | 09:03 AM
  #50
Warp Factor
Somewhat oversimplified, detonation is a situation where instead of burning progressively across the combustion chamber, there's a point where pressures or temperatures get so high, that the remaining unburned fuel spontaneously combusts all at once (a sudden explosion rather than a progressive burn).
Some strategies for combating this include enrichening the fuel mixture (which reduces combustion temperatures), using a higher octane fuel (which is less susceptible to self-ignition), retarding the timing (so peak pressure occurs farther after top dead center), and reducing power by reducing the throttle opening (on throttle-by-wire engines). Many systems will also control these parameters utilizing various temperature and pressure and speed and load sensors, using information gotten during testing of that particular engine/vehicle combination, in addition to knock sensors.
