Thanks for the replies! I look forward to getting them installed. We'll see how it performs after the slip-on's and then I'll decide if I should get the FP3 or not.
I bought the Rush slip-ons with 2" baffles. Although I feel I may have lost some torque, I really have no evidence to back it up so it must be in my head. They have a nice low rumble which is what I was looking for and they look just like stock.
I had a set of Rush slip-ons with the 2" baffles on my 2005 Deluxe. The bike is stage-2 with Andrews 48 cams. I lost a lot of low end response...they just don't have much back pressure and didn't work with my set-up. Only put about 80 miles on them, and decided to go with a good 2-1 set-up with adjustable baffles. The difference in low end response is dramatic.
I don't have a problem with Rush. They were well made and fit and finish was good, but just didn't work in this application. I think the 1.75" or 1.5" baffles will most likely produce more back pressure, so the OP should be on the right track. The 2" baffles were on the loud side too.
Labrador's suggestion for the lollypops is probably a good idea if you're loosing low end response.
The Rush slip-on's may work better with stock or stage-1 bikes, but I'd guess there's still some loss of low end response just based on my results.
I used Cycle Shack slip-ons and gutted stock mufflers (baffles drilled out) when it was stage-1 and the results weren't bad. None of these set-ups worked with the stage-2 cams.
I did not tune after installing the 2" slip-ons. I was told I would not need to do anything besides install the pipes and enjoy them. So far so good.
Originally Posted by eichacsj
You will love the 2" I love the more base tone. I have had both 1.75 and 2". I do not know your tune (download, your tune or dyno tune) but you will not notice your tune difference unless you have the printout taped to your instrument panel.
Yeah,They sound like there are washers shoved up your exhaust.I tried them and took them out.I have Rush with 1.75" and 2" baffles.I prefer the 2" as my bike seems to run better with them.
Well I'll find out tomorrow whether or not I'm happy with the 1.75" baffles. Dealer is going to throw them on for me during the 1000 mi service. I'll see how she runs for a few hundred miles and if necessary I'll buy a FP3.
