Electrical Issue
Old May 13, 2017 | 05:53 PM
cneal761's Avatar
cneal761
Stage IV
Default Electrical Issue
I need some assistance!! I have an '07 Softail Deluxe and last November we took a spill. In the process of repair, the guy doing the work obtained and painted the wrong front fender for my deluxe...I now have a fender tip light. A couple weeks ago I picked up the wiring to hook it up and did so by running the wiring to the two-wire plug under the fuel tank. Easy enough...right?? Well, now my headlight and my spots don't work but the tip light does. I have I have checked with a multimeter and have no power (12v) on the yellow (low beam) or the white (high beam) wires of the 4-wire plug coming from the battery. Of course, the orange/white has 12v on it. I have checked continuity on all fuses thinking that may be the issue, but all checked good. I looked up in the forum and checked the relays...feeling them "click", so I assume they are good. It appears I have developed a dead short somewhere, but where?? What would be the next place to check, because I'm lost!! What could have happened?? Please help!! Thanks!!
Old May 13, 2017 | 07:45 PM
gtmalone's Avatar
gtmalone
Check that all of the connectors are connected. Maybe something came loose with the work. The lighting circuit would not be on a relay - fuse only.
Do you have a wiring diagram for your scooter?
Old May 13, 2017 | 09:21 PM
cneal761's Avatar
cneal761
Stage IV
I have checked all the connectors in the area I have been working, but they are few.
Yes, I have the wiring diagram, thats what showed me where the plug in was for the tip light.
Old May 14, 2017 | 05:21 PM
FroggyFatBoy's Avatar
FroggyFatBoy
did you check the main connector under the tank. it may have come loose or a loose wire in the connector. I don't have the schematic in frt of me but the hi/low switch should control a relay to control the power to the the lamp. the switch on the handle bar is too small to handle the amp load a headlamp requires.
Old May 14, 2017 | 05:38 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Two wire plug under the tank? Without a schematic in front of me I'm wonder just what that two wire plug is. It has a negative return?
Old May 15, 2017 | 10:52 AM
nhrider1's Avatar
nhrider1
A dead short would take out the fuse...so I don't think that's the problem.
I suspect you have a problem with the ground. Try running a ground from the front forks to the chassis, it may have been removed during the repair and not replaced.
It's easy to check with a VOM. Look for continuity between the front forks ( or headlight shell) and the chassis, or measure voltage from the Hi/Low beam to the forks and again from Hi/Low beam to chassis ground. That will Identify a ground problem.
HD generally runs a ground strap from chassis to the front forks.
ajnigli
May 5, 2017 12:44 AM
Smash
Sep 29, 2015 05:19 PM
TedMan
Mar 9, 2012 08:56 AM
RandyDowdy
Sep 8, 2010 06:42 PM
dynamac
Dec 10, 2007 11:02 PM
