Hello installing fork mounted wind deflectors
Old May 26, 2017 | 10:56 PM
gtrplyr's Avatar
gtrplyr
Default Help installing fork mounted wind deflectors
Just purchased a new '17 Heritage Softail Classic and going to install hd fork mounted wind deflectors.
Question: Do the deflectors mount on the outside of the windshield, or in-between the windshield and the passing lights, or inside the passing lights closest to the forks.
Thanks!
Old May 27, 2017 | 04:55 AM
alexknight2000's Avatar
alexknight2000
I would also like to know the answer to this.
Old May 27, 2017 | 08:36 AM
Griff012FLHX's Avatar
Griff012FLHX
I just recently added the deflectors to my 17 FLSTC.
Forget the instructions they came with....
Mount them on the out side....
Old May 27, 2017 | 09:07 AM
rbert0005's Avatar
rbert0005
Could one of you guys send me a pic of the blow up view of the instructions?
I need to get the hardware but don't know what I need.
Bob
Old May 27, 2017 | 10:32 AM
Glyder54's Avatar
Glyder54
From another poster on here.
Old May 29, 2017 | 07:38 PM
Gommee's Avatar
Gommee
Devil's Advocate
Check out this thread:
https://www.hdforums.com/forum/softa...our-fangs.html
Old May 29, 2017 | 09:14 PM
langwilliams's Avatar
langwilliams
I've read to watch you temps with those, they can affect how much air hits the motor.
Old May 30, 2017 | 01:21 AM
Aogmitch's Avatar
Aogmitch
Bob
Shouldn't need any hardware. You may have to adjust your turn signals to clear them. I just removed the upper bolt, then hold the deflector up and put the upper bolt back in, but leave slightly loose. Then remove the lower bolt, swing deflector into position, then install lower bolt. Tighten both bolts up, then move to the other side.
Old Jul 14, 2019 | 10:25 AM
Dieselsoftail's Avatar
Dieselsoftail
what do you heritage guys do to get at the nut the loosen the turn signal? factory book isnt a help unless I'm missing it . no socket with the wire running up to the aux lamp. been trying to just pull em seems theyre just in the way. gotta push gs a little forwrd, they just hit the crash bar
Old Jul 15, 2019 | 07:47 AM
Amanelot's Avatar
Amanelot
I bought a cheap socket and took a dremel to it, looks like crap but works perfectly.
