2003 Fat Boy will Crank but not Start
Old Jul 10, 2017 | 03:37 PM
Jchaiyo's Avatar
Jchaiyo
Originally Posted by 03fattyaz
You can die!....? Maybe if you're on a pace maker...
go ahead and try it. Let me know how you feel after 1200- 45000 volts go thru you.
Old Jul 10, 2017 | 03:38 PM
Jchaiyo's Avatar
Jchaiyo
Originally Posted by rastajacob
(I posted this over in the electrical section as well, but figured I ask you all over here as well). So I am having problems with starting my bike. I am at a loss. The bike was running fine for months, and now, it cranks and turns over but will NOT start. I turn the ignition to on, fuel pump cycles, I hit start, and then it cranks but will not start. It is a 2003 FLSTFI (Fuel Injected model). Any suggestions as to what may be the cause? Thanks.
https://youtu.be/g9ou00B8jTw
so Rasta man, what's the deal?
Old Jul 11, 2017 | 09:23 AM
hdbob2006's Avatar
hdbob2006
I've worked on cars and motorcycles all my life,so I've touched spark plug wire ends several times,vehicles cranking over or running.[by accident]It'll give you a hell of a jerk,but death?? Silly.
Rode my mini bike years ago with the seat off-old B&S spark plug shocking my *** at every bump.[I'm still alive]
Old Jul 11, 2017 | 10:04 AM
Tom84FXST's Avatar
Tom84FXST
I worked in a forklift shop when I was a kid, we used to grap sparkplug wires on purpose, and reach over and touch someone to shock them...most everything was points back then...these new electronic ignitions really hurt when they get ya...but I still havn't died.
Old Jul 11, 2017 | 10:50 AM
Scudda's Avatar
Scudda
Is there a tuner on the bike? they won't fire the plugs if the cranking voltage is low..trust me I found out the hard way
Old Jul 11, 2017 | 03:33 PM
rastajacob's Avatar
rastajacob
Thanks for all of the replies. To answer some questions, there is fuel in the bike. I am getting spark and in fact, have changed the plugs for new ones two weeks ago. The bike has been sitting for about 4 years (i lived out of state and it lived in my folks garage on a tender for that time). I haven't checked an of the fuses or the fuel pump. And there is NO tuner on the bike at all (thank goodness for that). I will attempt to get back to you all by the weekend with an update. Thanks again !!
Old Jul 11, 2017 | 04:00 PM
Big_Al47's Avatar
Big_Al47
Bad/spoiled gas maybe? New spark plugs correct gap?
Old Jul 11, 2017 | 05:45 PM
baloot-boy's Avatar
baloot-boy
Okay see you didnt tell us all of that in the beginning. Dump the gas first and foremost and put some fresh fuel in there. Then move forward with the suggestions posted.
Old Jul 11, 2017 | 05:46 PM
dfwhockey17's Avatar
dfwhockey17
A common issue on our bikes is the fuel pressure regulator housing breaking and causing the fuel to dump back into the tank and the result is a bike that cranks but doesn't fire. How full is the tank? If it is low enough for the regulator and housing to be above the fuel level this will happen. Also, a pinhole in one of the fuel lines in the tank will cause the same symptoms. A simple diag is to take the gas cap off and shine a flashlight in the tank. When you turn the ignition on if you see fuel spraying in the tank you know you have one of these issues. This is assuming you have spark of course. If the problem is the regulator housing (we come across this 5-6 times a year at the shop), Trask makes a billet version that won't break.
I read that the bike has been sitting for four years. Did you drain the tank and out fresh fuel in it? You could be experiencing a number of things beyond what I mentioned above. The fuel pump, filter, regulator or injectors could be clogged. Can you get it to a shop that can do a fuel pressure test for you? How does the inside of the tank look? Is the liner peeling or is the tank rusting?
Old Jul 11, 2017 | 05:48 PM
TeaRunner's Avatar
TeaRunner
If the bike has sat that long, the gas could have gone bad. Or, more likely, it sat with ethanol gas in it and it's eaten up your fuel lines/strainer/pump.
