08 Heritage front end rattle
Old Jul 11, 2017 | 09:31 AM
gonderk's Avatar
gonderk
Stage IV
Default 08 Heritage front end rattle
I hit a large pot hole yesterday. Now every time I hit a bump there is something rattling in the front end. Bike handles the same and no vibration at speed. I checked everything external on the front and nothing is lose. Any ideas? Could it be a broken front fork spring?
Old Jul 11, 2017 | 10:23 AM
jeepcj578's Avatar
jeepcj578
6th Gear
Check the neck bearings, grab the bars and push and pull on them with only back brake on to see if you have any movement. I know when dad hit a big pothole on a trip it knocked them out on his ultra
Old Jul 11, 2017 | 10:33 AM
Mike Lawless's Avatar
Mike Lawless
In addition to Jeepcj's suggestion, see if the there's anything loose in the headlight housing.
I had the same thing going on and it turned out to be the "relay box" for my LED headlight that was loose and rattling around. Using a couple zip-ties tidied things up and no more rattle.
The funny thing was that the rattle was also present at certain engine rpm, giving the illusion that the engine was clattering at certain RPMs. Harmonic resonance
Old Jul 11, 2017 | 10:47 AM
gonderk's Avatar
gonderk
Stage IV
Thanks guys!! I will check those out! I have recently installed LED lights, so that is a definite possibility. I will also check the bearings.
Old Jul 11, 2017 | 11:06 AM
rbeamj's Avatar
rbeamj
I had the same rattle and turned out to be the front fender bulb that I had installed. It came from custom dynamics and was an LED.
Quick and and easy to check out. Just remove the lense
Old Jul 11, 2017 | 11:47 AM
gonderk's Avatar
gonderk
Stage IV
I haven't checked that either, but I will, Thanks!
Old Jul 13, 2017 | 07:57 AM
gonderk's Avatar
gonderk
Stage IV
Ok, I have checked all of the suggestions above. Everything seems to be tight. I repositioned the headlight relay and fastened. There is no change in the noise. Thanks for all of the suggestions. Anybody have any other ideas?
Old Jul 13, 2017 | 08:38 AM
heybaylor's Avatar
heybaylor
look up "fall away" adjustment on the head bearings.
Labrador
May 20, 2017 03:56 PM
bloomington g
Aug 24, 2015 11:28 PM
DaSham58
Electrical/Lighting/Alarm
Jul 8, 2013 07:47 AM
SJ58
Dec 28, 2011 02:26 PM
Talldog
Sep 12, 2011 03:43 PM
