Sunpie LED causing error code
Old Sep 13, 2017 | 10:15 AM
rcpbob's Avatar
rcpbob
Originally Posted by BLKDLX
My Sunpie LED headlight is causing me to get a error code, apparently it thinks the light is burnt out because it draws too low of voltage. It's easy enough to clear the code, but I have to do it daily. Has anybody figured out a way to correct this? Other than that I am extremely happy with them, but this is a pain.
Don't see what bike you have, so I'll ask. Do you have fender tip lights and are they working ? I put the LED headlight and spots in, and I started getting a red light just to the right of speedometer. Showed an error code for low voltage. Found both fender tip bulbs blown !
Old Sep 13, 2017 | 10:22 AM
BLKDLX's Avatar
BLKDLX
I have a 2017 Softail deluxe, with just over 1000 miles on it. I am not near the bike now so I'm not sure if there's laying on the front fender or not, but I can't imagine they would both be blowing already. Also I would've thought that if they were blown the light will stay on continuously it comes and goes.
Old Sep 13, 2017 | 04:43 PM
rcpbob's Avatar
rcpbob
Yeah, you would think. But that's what mine did, maybe it resets every time you cycle the key. Ride On !
Old Sep 19, 2017 | 05:24 PM
BLKDLX's Avatar
BLKDLX
Originally Posted by kculp
Mine came (other Chinese led) with anti flicker, yes it will just plug and play but you need that anti flicker.
I received in the mail today two plugs from Sun Pie. I thought this anti-flicker adapter went in the headlight, but since they sent two now I'm wondering if they're supposed to go for the two passing lamps? Or did they just send me an extra one? Can anybody confirm if this adapter is supposed to go behind the headlight or does it go on the two passing lamps?
Old Sep 19, 2017 | 08:08 PM
BLKDLX's Avatar
BLKDLX
thanks to gdishman for the help. My battery connections are tight and my voltage is fine. The harness did indeed go with the headlamp, it is installed so I will ride it for a few days and report back, it has not thrown a code in the very short time I had to ride after I installed it.
Old Sep 20, 2017 | 07:48 PM
kculp's Avatar
kculp
Sorry, wasn't following the thread. This is for the thing: LED Headlight Canbus Error Free Anti Flicker.
The passing lights were hardwired, so no the antiflicker goes into the headlamp.
It was really intuitive, looked like a short extension (pigtail), here's an example link to 3bay. I'd have to tear it apart to get a part number, but just make sure it's the same shape as your adapter to the bike.
Old Sep 20, 2017 | 08:49 PM
BLKDLX's Avatar
BLKDLX
yes, I already installed it, they just sent two I don't know why.
Old Sep 21, 2017 | 10:04 AM
Myhog2's Avatar
Myhog2
Stage II
Anti flicker on Amazon.. I can only find pairs for cars..
Harleys with CANBUS need this.. pre CANBUS do not, and only $12 a pair
Amazon Amazon
Old Sep 21, 2017 | 08:39 PM
SgtThump's Avatar
SgtThump
Same thing here. This anti-flicker harness thing is huge. Did you somehow fit it inside the headlight housing?
Old Sep 21, 2017 | 10:32 PM
BLKDLX's Avatar
BLKDLX
The headlight housing on my deluxe is huge, it fit in there with plenty of room to spare
RedBeard330
Electrical/Lighting/Alarm
Mar 29, 2023 09:31 AM
Passing Lane
Dec 7, 2018 06:56 AM
dc1450
Feb 23, 2013 06:46 PM
Zener
Nov 23, 2012 07:50 PM
scorpion65
Nov 12, 2012 04:31 PM
