Problem with my 12 Deluxe
Old Aug 30, 2017 | 09:05 AM
Mongo40's Avatar
Mongo40
Default Problem with my 12 Deluxe
I've got a unexplained wobble, the only other time I've felt anything like this was when I got a flat on the rear of one of my bikes, it started this summer or at least that's when I noticed it, haven't done anything to the bike to change any thing, air in tires is good, but when I get up to speed then let off a little I get the wobble, like when following a semi an caught in his wash, initially I thought the Memphis shades lowers I had was causing it so removed them an windshield an still get it, seems most noticeable when I get up to 75-80 mph then let off, while accelerating its fine its when I go to maintain my speed that I get it, not sure whats causing it but its definitely making me uncomfortable to ride the bike. Any ideals ???
Old Aug 30, 2017 | 09:19 AM
imjdoggie's Avatar
imjdoggie
Riser bushings, wheel weights, bad tires possibly?
Old Aug 30, 2017 | 09:22 AM
dfwhockey17's Avatar
dfwhockey17
If your suspension is working properly and your tires are fine I would look at a loose steering stem or possibly loose (rear) spokes. Both of these will cause the symptoms you are seeing.
Softails are odd in a way that A LOT of them have this wobble you describe, and it can be caused by a number of things, you may even try adding 3 more psi to the tires and see if it helps. Fat Boys are the worst for this and you can spend a lot of money throwing parts at it to get it right. My '05 Deluxe has 16" apes and a 21x3.5" front wheel I will occasionally get a slight wobble at the same time you do but it is rare and I have not worried about it. I was expecting it to be worse being such a tall front end but it isn't. I did tighten the steering stem to get the fall away correct after adding the weight of the new parts to the front end though.
Old Aug 30, 2017 | 10:57 AM
Mongo40's Avatar
Mongo40
I'm going to put it up on the lift table this afternoon an check all the spokes, my tires say 40psi cold an that's what I'm running in them, might try to add a 2 or 3 more just to see if that helps any.
Old Aug 30, 2017 | 05:56 PM
jkinner's Avatar
jkinner
How many miles on the tires, how old are they? While on the jack check the fall away.
Old Sep 1, 2017 | 08:40 AM
Mongo40's Avatar
Mongo40
We'll figured it out pretty quick, put it up on the table an raised the rear end, could wiggle the rear wheel side to side by hand! Every spoke on it was loose!!! 30 yrs of riding, I've had a spoke loose once in awhile but never had one get like this before, I always check them when I clean my rims an when one is loose I'll tighten it. Rim has a fairly new Dunlop on it an was balanced, I might try some of that Ride Right stuff you squirt inside tube.
Old Sep 1, 2017 | 08:51 AM
Redlegvzv's Avatar
Redlegvzv
Interesting thread.
mike camp
Mar 14, 2016 09:43 PM
stephen.baker
Wheels/Tires
May 10, 2013 07:50 PM
bladeguy
Jul 11, 2012 11:28 PM
tq745
Apr 12, 2012 12:55 AM
sidewinder
Dec 17, 2005 11:48 PM
