won't turn on
Old Sep 18, 2017 | 12:58 PM
chrisj49's Avatar
chrisj49
Do you hear the fuel pump prime when you power on?
Old Sep 18, 2017 | 01:59 PM
chaslednicky's Avatar
chaslednicky
3rd Gear
Yes I hear fuel pump
Old Sep 18, 2017 | 09:24 PM
langwilliams's Avatar
langwilliams
have you pulled in the clutch an hit the starter button? I had this happen an it was the neutral switch sticking an if the "N" wasn't lit it wouldn't do anything without the clutch pulled in.
Old Sep 18, 2017 | 11:06 PM
Hoginedgewood's Avatar
Hoginedgewood
Neutral switch? Was that HD?
Old Sep 19, 2017 | 11:11 AM
langwilliams
yes...the older bikes would start in gear an jump forward...my '15 won't...if the "N" light isn't on I have to pull in the clutch to get it to start. Look on the bars behind the clutch lever an you will see a button it pushes in when pulled.
Old Sep 19, 2017 | 11:20 AM
langwilliams
here's the clutch switch on the bars, item 21:
http://partsfinder.onlinemicrofiche....0TURN%20SIGNAL
here's the neutral switch item 28
http://partsfinder.onlinemicrofiche....ING%20ASSEMBLY
Old Sep 19, 2017 | 11:21 AM
chrisj49's Avatar
chrisj49
OP has a 2006. My 2006 Heritage does not have a neutral switch.
1. You are getting power to the bike
2. The run/stop switch is working (you hear the fuel pump prime).
3. No noise at all from the starter.
You need to check the path from the starter switch to the starter - switch, starter relay, etc. Put a test light or meter on the starter solenoid wire and see if you get power when you push the start button.
Highly recommend you buy the service and electrical manuals - the electrical one has procedure trees that will help track down these types of problems.
luvmypeis
Sep 25, 2017 05:45 PM
John LaRoe
Shovelhead
Sep 15, 2016 12:55 PM
OKSlick
Electrical/Lighting/Alarm
Jul 9, 2014 05:27 PM
Vambo666
May 30, 2014 08:16 PM
Gato1
Mar 2, 2012 11:33 PM
