Turn signals
Old Sep 21, 2017 | 04:41 AM
Joel282's Avatar
Joel282
Default Turn signals
I have a 2001 Fatboy. I bought the bike recently. The previous owner told me the signals diddnt work but he diddnt know why and doesn't know when or how they stopped working cause it was like that when he bought it from the original owner in 2012. The fronts are LED and I believe the backs might be too. I followed all the wires to each light and they are spliced in to the wiring like they should be and no damage anywhere to the turn signal wiring. I'm not sure if there is a load equalizer on the bike.
Neither side works and signals don't blink on the cluster either. Doesn't work when on ignition or accessory. 4-way hazards don't work either. All other lights operate as they should.
Ive read a lot of threads on this forum about this problem that pointed to the TSM but before spending $160 on a part I (may) not need I figured I would see if anyone else has any ideas.
Thanks!
Old Sep 21, 2017 | 05:00 AM
RANGER73's Avatar
RANGER73
Unplug the TSM and use your Owners Manual and DMM to check for power at the plug.
Old Sep 21, 2017 | 05:13 AM
Joel282's Avatar
Joel282
I don't have a manual yet. Anywhere I can download the pages that cover this?
Old Sep 21, 2017 | 05:19 AM
RANGER73's Avatar
RANGER73
Google is your friend. Look for wiring schematics for your year and bike.
http://apoint.co/wiring/2001-harley-wiring-diagram.html
Start here.
https://www.google.com/search?rlz=1C...w=1600&bih=770
Or here. pick your poison.
Old Sep 22, 2017 | 08:26 PM
Joel282's Avatar
Joel282
So my brother checked out my bike today, he's the electrical guy, this is what he said;
Put this on your forum...
"Tested output from blinker switch at tsm module. Used digital volt meter and found ground on the input wire from the switch to the tsm. When turn signal switch is pressed it briefly removed ground then came right back."
is that normal operation thus far leading us to believe it's the module?
Old Sep 22, 2017 | 09:09 PM
langwilliams's Avatar
langwilliams
it could be that the led's don't draw enough power so the tsm thinks the bulb is blown. I had this when I put leds on my V rod...I had to put a load equalizer on....I used LED run/turn/brake...an only had to put a equalizer on the turns.
Old Sep 23, 2017 | 12:02 AM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
On my '13 Blackline, I was told it needed a load equalizer to keep the dash light from flashing fast. The turn signals flashed correctly but the dash did flash fast...big damn deal. I never put the equalizer on.
Old Sep 23, 2017 | 07:10 AM
Joel282's Avatar
Joel282
What I find confusing is the signals on the cluster don't flash either. Nothing at all.
Old Sep 23, 2017 | 11:13 AM
Joel282's Avatar
Joel282
I just replaced the TSM. Signals flash. They flash a few times then the 4 ways go on and then they don't and then they do. They are blinking fast, then 4 days again.
i understand I need a load equalizer for the led lights but would that also be causing the 4 ways to turn on randomly too?
Old Sep 23, 2017 | 11:26 AM
Joel282's Avatar
Joel282
Flashing 6 times, bike has no security.
thegars
Electrical/Lighting/Alarm
Feb 18, 2015 05:18 AM
blacklabel213
Dec 13, 2013 04:56 PM
Elvira
Feb 5, 2012 12:19 PM
harleylay
Dec 29, 2009 08:14 AM
2Devious
Aug 3, 2006 08:10 PM
