Difference between Softail and Touring engine cases?
Old Sep 27, 2017 | 03:47 PM
martin10's Avatar
martin10
Default Difference between Softail and Touring engine cases?
I have read the Softails have a bit of a different oiling system. And the extra balancer. Can anyone explain the differences.
Old Sep 27, 2017 | 04:04 PM
Snowyone's Avatar
Snowyone
Default Diff
The Softails have two balancing shafts that are chain driven off the pinion side shaft. There is an extra oil hole in the block that feeds oil to these shafts. The Touring models don't have this hole and the plate the oil pump is attached to, you block the feed holes off with supplied plates and screws. This is my observation on a 2011 and 08 Softail and an 02 and 06 Dyna and touring.
Old Sep 27, 2017 | 05:57 PM
adm's Avatar
adm
I believe the 2018 softail counterbalancers are now gear driven rather than chain driven. Basically an efficiency improvement on the Twin Cam B motors.
Can't speak to the oiling though...
Old Sep 27, 2017 | 11:31 PM
Prot's Avatar
Prot
Are you talking Evo, Twin Cam, or M8?
4 inch pistons
Mar 17, 2018 08:04 PM
just plain john
Nov 7, 2017 09:09 AM
FLYER
Aug 27, 2017 07:20 AM
magazine
Jul 10, 2013 01:36 PM
dpprSoup
Jul 7, 2009 10:29 PM
