A question about Softail TC cam chain upgrade
Old Mar 16, 2018 | 07:51 PM
4 inch pistons's Avatar
4 inch pistons
Default A question about Softail TC cam chain upgrade
My Indy is closed at the moment. I took the bike out for a few miles today and when I got home the oil did not touch the dipstick. The pressure is fine but I was wondering if the upgrade with the new oil pump affected the way you check the oil?
Old Mar 17, 2018 | 11:23 AM
cmashark's Avatar
cmashark
No, but the oil pump may have bad alignment causing it to sump.
Old Mar 17, 2018 | 11:26 AM
cmashark's Avatar
cmashark
My softail only holds 3 quarts. Manual says to pour in 2 quarts, run it to temp, and top off with as much is needed. Are you sure he put the 3rd quart in after he was done?
Old Mar 17, 2018 | 06:30 PM
4 inch pistons
He did not. It seems it was over a quart low. Mech says he can’t remember toppings it off. Hummmm
Old Mar 17, 2018 | 08:04 PM
95th 1200's Avatar
95th 1200
Run it halfway between full and add. If you fill it right to the full mark it'll puke out the breather after high RPM or hard use.
Pops98
Feb 1, 2015 05:05 PM
KCelectraglide
Engine Mechanical Topics
May 22, 2014 08:00 PM
KCelectraglide
May 10, 2014 01:55 PM
Streetrunner
Apr 15, 2013 10:38 PM
ron bayless
Exhaust System Topics
Jun 16, 2009 04:29 AM
