Hi guys
I'm fitting in a Vance and Hines VO2 AC.
There is this wire which came off the original as pictured below.
Where do I or what should I do with it?
"The active exhaust system utilizes an actuator valve located in the rear exhaust pipe which is connected to a servo motor via a cable. The valve position automatically adjusts to enhance engine performance.
Heres a diagram showing where it would be if fitted -
I saw the actuator.
It behaves like an open and close valve.
My local shop actually soldered the actuator to be opened at all times.
I dunno if that is a blessing in disguise or not.
