Front end wobble-07 Fatboy
Old Aug 9, 2007 | 03:37 PM
  #31
FatIndy's Avatar
FatIndy
Default RE: Front end wobble-07 Fatboy
I have the same wobble on mine. I have about 6400 miles on mine and just started to notice it. I also noticed it is really starting to pull hard to the left if I take my hands off the grips. I will be going by the dealer to have it checked out.
Old Aug 9, 2007 | 05:55 PM
  #32
jkelley's Avatar
jkelley
Guy's it IS THE STEERING HEAD BEARINGS!!!!
Most techs are just taking off the chrome cover and checking to see the nut is tight, or just snugging it up. This will not fix this issue. You have to follow the manual..
You can tighten that nut all day and it will not help you unless you loosten the fork tube pinch bolts to allow thebottom fork bracket to move up slightly so the bearings can be tightened correctly. It is not that difficult to do if you jack it up and follow the procedure. I personally set mine a little tighter than the procedure just because I like the feel.
Old Aug 26, 2007 | 09:37 PM
  #33
Lamo70's Avatar
Lamo70
I had a wobble today for about two minutes, but at 60 mph, with a 35 mph cross wind hitting me. I hope its only the lack of air going through the front rim....
Old Oct 5, 2007 | 11:22 PM
  #34
07 Fatboy's Avatar
07 Fatboy
I got the wheel and tire replaced by Harley and it fixed the decel 45 to 40 mph wobble, just wanted to let others to know what fixed mine after dealer tried so many things.
cecil1
Oct 18, 2007 07:59 PM
dragonfiregirl
Apr 1, 2007 09:14 AM
Axeman
Jan 23, 2007 03:27 PM
grasman
Dec 31, 2006 08:52 AM
streetglider
Jan 20, 2006 12:07 PM
