i have side mount license plate bracket with brake light...i would like to have my turn signals in the rear running lights as well....like the front. any ideas for me?
yeah, but they had to rewire my signals...brake light for the new one...and thats like a plug in deal...i just dont think it will work on mine....maybe it will?
I have the Kuryakyn LED brake light, but it is pretty dim. If you want to be seen, get Radiantz LED's in your signals with the run/brake module. You can order this stuff from biketronics.com; they are pretty good to deal with.
[align=left] [/align]
Hi boone,
I changed my turn signals to a "duel element" setup. This allows the bulbs to be lit all the time increasing visibility. I also mounted a bullet light off the swingarm and wired it to the closest hot wire and ran a ground wire as well. I now have % light back there all lit including my rear fender tip light. I also made every one-even the bullet-a blue dot which gives off a kind of purple glow which draws attention to the bike. Hope this help open your mind up to more ideas. I have also see swingarm tip lights available. Good luck!!
