'01 fatboy w/EFI won't crank
Old Apr 23, 2018 | 02:10 PM
Pech's Avatar
Pech
Stage I
Default '01 fatboy w/EFI won't crank
with a fresh battery installed, I turn the ignition and place switch to RUN... the lights come on and the fuel pump can be heard operating. I hit the START switch and nothing happens. I tried "tapping" the starter while hitting the switch and nothing. The bike was operating normally in January but has been garage kept since then.
Old Apr 23, 2018 | 03:21 PM
Will Belden's Avatar
Will Belden
Is there a loose grounding wire for the starter?
Old Apr 23, 2018 | 04:04 PM
Flstcjay's Avatar
Flstcjay
Bad relay, starter switch, or starter. Jump the starter to see if it cranks. If the starter is good check the relay, then the switch. Could be corrosion at the starter pole.
BlackDenim&Chrome
Apr 2, 2025 07:30 AM
jim70
Electrical/Lighting/Alarm
Nov 16, 2015 05:21 PM
75hdxlh1000
Aug 10, 2012 09:09 AM
sbarnes489
Oct 27, 2010 02:32 PM
Beauregard
Jun 2, 2009 08:29 PM
