Right side turn signal problem
Old Apr 27, 2018 | 07:48 PM
John Secosky's Avatar
John Secosky
Default Right side turn signal problem
I have a 92 Fatboy, both front and rear turn signals should be on all time (rear dim), and when engaging the turn button they flash, well the left side is working properly, however the right side when in normal running the rear is not on and when pushing the turn button the rear is just solid light and the front doesnt come on at all, i connected the right front to the left and works fine, i read there is turn signal modules, i have right tank off, and all i can see are 2 male to female connectors, unless the modules are behind the left side, cant really see, and its finally getting nice in Ohio, ive only got to ride twice, thanks for any help and input, ride safe!!!!
Old Apr 27, 2018 | 08:46 PM
14GuineaPig's Avatar
14GuineaPig
In stock form, the rear turn signals are only turn signals and do not operate as running lights. They use a single element bulb. The front lights are turn signals and running lights and use a 2 element bulb. Check all the bulbs, you can even switch the bulbs from right to left to see if the problem moves. If you have mods done to the lights then you'll have to lists them when asking for help.
Old Apr 28, 2018 | 04:16 AM
John Secosky
Thanks, didnt know that, so it must have been modified, the rear signals are dual element bulbs, i did switch the bulbs, also i connected the right front to left side and works fine, do u know where i may be able to see a wiring diagram, it would be major help, im an elactrician by day, so im quite familiar with voltage, but helps knowing how the system is suppose to work, and when i tested front right, it tested 12 volts, should light up,
Old Apr 28, 2018 | 07:07 AM
14GuineaPig
Try this link: https://serviceinfo.harley-davidson....wiring&id=5524
If it works, you bike will be on page 153 of 276 pages.
If the link doesn't work for you, try going to the HD Service Info Portal, and in the search box at the top right of the page, enter "1992 wiring". On the top of the search results should be "Wiring Diagrams & Electrical Troubleshooting Guide - 1991 & 1992 All Models".
You can also view your Owners Manual by entering your VIN here: https://serviceinfo.harley-davidson....cle/lookupForm
Look under Vehicle Documents and you should find 1992 All Models Owner's Manual
OneWound
May 14, 2018 05:17 PM
Justin727
Electrical/Lighting/Alarm
Apr 11, 2018 08:12 AM
z28kilr
Apr 16, 2010 11:58 AM
Talent Scouter
Sep 1, 2006 09:20 PM
rocamotacoca
Feb 21, 2006 12:18 AM
