Shifting a 2007 softail
Old May 26, 2018 | 01:13 PM
SPRINGER's Avatar
SPRINGER
Originally Posted by Bone Doc
It sounds like, no pun intended, you need to get yourself a tachometer. The problem with relying on a tachometer to know when to shift is that your attention will always be on the tach and not on the road.
This is true and what can also make it worse is if a person is riding in heavy traffic where a car can change lanes in a split second and paying too much attention to a tach instead of the traffic could open the door for a serious accident.
Old May 27, 2018 | 12:44 AM
Thingfish's Avatar
Thingfish
You can shift by feel just fine. These bikes also have a wide power curve, meaning you’d have to try really hard to shift too early and lug the motor....you’re not going to hurt anything by reving higher so when in doubt shift a little later. Better to shift late than too early, but again these motors pull like tractors so “early” is relative. 1st is shorter so you’ll hit 2nd fairly quick..after that they are very stretchable. 5th can be ridden anywhere between 50mph and 90mph easily without being “wrong”...or you can jump into 6th by 60 if you’re just feeling like putting down the road. Basic guide is around 12 mph per gear as a low shift point, but you can run them much higher if you like to...and some people do.
shift too early? No problem...you’ll feel the bog in power, just downshift and ride on. Do it all the time and it’s not great for the motor, but you’ll get a sense of how to avoid it quickly enough.
Dirtdiver38
Softail Parts
Aug 12, 2017 10:15 PM
lunar00
May 24, 2017 01:36 PM
mrb0b
Apr 1, 2012 11:23 PM
oct1949
Jun 29, 2009 12:04 AM
lencap
Oct 8, 2007 10:33 AM
