Shifting a 2007 softail
Old May 13, 2018 | 05:33 AM
Joshua Dolan's Avatar
Joshua Dolan
Stage II
Default Shifting a 2007 softail
hey so I have 6 speed 2007 softail custom and it’s my first bike. I’m just looking around trying to find out when I should be shifting gears? Cause I don’t have rpm counter and I just kinda find it hard to believe the my bike shifts into 6th gear at 55 when my max speed is 120. So if I can get any recommendations on where to look for the answer or if someone can tell me that would greatly be appreciated.
Old May 13, 2018 | 05:43 AM
Flstcjay's Avatar
Flstcjay
Depends on rate of acceleration. If you are just putting away from a light on a surface street you want to switch gears once RPMs are high enough that the engine won’t lug in the taller gear.
If you are hard on it in full race mode, you want to switch gears just prior to the point where the pistons seek daylight.
Generally, normal driving is in between these two points.
Old May 13, 2018 | 08:21 AM
jkinner's Avatar
jkinner
My general rule unless I need to merge pass or get out of the way is 1st-2nd @10-15 mph, 2nd-3rd @25, 3rd-4th @ 35, 4th-5th @ 45, I don't use 6th Until 65+. JMHO, It works for me, 2016 Deluxe.
Rise safe.
Old May 13, 2018 | 10:21 AM
uncle kebo's Avatar
uncle kebo
The answers are in the owners manual. Honestly (and this is constructive) I think you need to understand the feel and need of when to up and downshift - if you dont youre dangerous..
Old May 13, 2018 | 12:51 PM
SPRINGER's Avatar
SPRINGER
Back when I was learning how to ride/drive a vehicle, I never had a tach so I learned how to shift by listening to the sound of the motor. It's amazing sometimes what a person can learn by just listening to the sound of their motor.
Old May 13, 2018 | 05:28 PM
uncle kebo's Avatar
uncle kebo
Bingo!
Old May 26, 2018 | 12:58 AM
Joshua Dolan
Stage II
Default I’m partly def
but the thing is I’m partly def so it’s hard to hear through my helmet with the little hearing I have
Old May 26, 2018 | 03:11 AM
Bone Doc's Avatar
Bone Doc
It sounds like, no pun intended, you need to get yourself a tachometer. The problem with relying on a tachometer to know when to shift is that your attention will always be on the tach and not on the road.
Old May 26, 2018 | 05:23 AM
saltlick's Avatar
saltlick
I got a 2008 softail custom, I don’t shift into 6th gear unless I hit the freeway or a good stretch of road I gotta be going over 60mph to hit 6th gear anything under 65-60 mph engine is lugging.
Old May 26, 2018 | 06:17 AM
capeohara's Avatar
capeohara
sell your bike!
