Oil viscosity
Old May 28, 2018 | 08:40 AM
dakers38's Avatar
dakers38
Stage II
Default Oil viscosity
what is the viscosity for the clutch oil and chain oil in a Harley softail heritage classic. I know the quanties but can't find a reference for viscosit
Old May 28, 2018 | 11:49 AM
mplazz's Avatar
mplazz
You don't mention what year. For 2003 Softail, the manual states using 20w-50 (preferred), 15w-40 or 10w-40 in the crank case. It does not state the viscosities of the oils for the Primary or Transmission, only the HD part number. Some Harley dealers put the same oil in all 3 holes.
Old May 28, 2018 | 12:17 PM
Flstcjay's Avatar
Flstcjay
Old May 28, 2018 | 12:32 PM
langwilliams's Avatar
langwilliams
I just put rotella 15w40 in mine an it shifts well an clutch feels good.
Old May 28, 2018 | 01:54 PM
dakers38's Avatar
dakers38
Stage II
Thanks, that's a help,and mine is 2001 Softail Heritage Classic
Old May 28, 2018 | 03:00 PM
blackxpress's Avatar
blackxpress
Your manual doesn’t say because it really isn’t all that critical. Just don’t put gear oil in there. It tends to be too heavy. Some guys use 20w50 motor oil and some guys use ATF fluid. Me? I prefer primary chaincase oil since that’s what it’s for. Right now I’m running HD Formula +, which is basically straight 50w oil. I’ve used Lucas and Bel Ray in the past and can’t really tell any difference between those and the Formula +. Some people say you should avoid oils with extra friction modifiers because they can cause clutch slippage. Personally I just figure if it says primary chain case on the bottle I’m good to go regardless of the actual viscosity.
Old May 29, 2018 | 06:16 AM
heybaylor's Avatar
heybaylor
Same here in all my bikes, 30 years and still running
Old May 29, 2018 | 12:16 PM
Tom84FXST's Avatar
Tom84FXST
Been running gear oil in mine for 10 years, with no problems...really not critical
Steve Sportster
Milwaukee Eight (M8)
Nov 7, 2018 08:03 AM
Kayakeur
EVO
20
Sep 10, 2015 07:24 AM
SportsterSnow
Sep 8, 2014 05:06 PM
johnod
EVO
Jun 1, 2014 01:56 PM
aoehero
Oil Archive (no new posts)
Jun 16, 2011 09:44 PM
