Neutral Light
Old Jun 8, 2018 | 07:51 PM
cgmartine's Avatar
cgmartine
Default Neutral Light
I have a 2006 Heritage Softail. I recently noticed that my neutral light is not coming on. All other lights come on. Could this be a burned out bulb, or something else?
Old Jun 8, 2018 | 09:09 PM
Hey Man's Avatar
Hey Man
Check that first. Always check the easy stuff first. Then check the ground and the connection at the switch.
Old Jun 8, 2018 | 09:35 PM
langwilliams's Avatar
langwilliams
my 2015 slim wouldn't light up sometimes. I'd pop in an out of gear an sometimes put it in second an lightly let the clutch out then go into N an it would come on.
Old Jun 9, 2018 | 06:58 PM
HDJIM1158's Avatar
HDJIM1158
Ditto what "Hey Man" said......"Check that first. Always check the easy stuff first. Then check the ground and the connection at the switch."
I had the same problem... I found the wire boot was loose... pushed it back down and all was well. Most likely came off from the brush I was using while washing the engine.
Ride Safe JIM
balloo
Jun 24, 2019 06:49 PM
yso191
Sep 13, 2009 09:09 PM
DiegoKing
Mar 30, 2008 12:52 AM
Leda1316
EVO
Jan 5, 2008 03:09 PM
2002bigbored
Jun 22, 2007 08:25 PM
