Neutral Indicator Light Not Working
Old Jun 21, 2019 | 11:07 PM
balloo's Avatar
balloo
Default Neutral Indicator Light Not Working
2008 Heritage - - all of a sudden the blue light does not come on when in neutral.
Any idea what caused this? And how do I fix it.
Thanks.
Old Jun 24, 2019 | 10:10 AM
MNtadpole's Avatar
MNtadpole
I'm not claiming to be an expert, but assuming that your lighting and wiring to the indicator is good to go, try checking to the neutral switch on the engine as a possible failure. IDK how you would do so, but it seems like a logical issue.
Old Jun 24, 2019 | 06:49 PM
RANGER73's Avatar
RANGER73
the light on mine is green
Did you check the bulb
the switch is on top of the transmission,
if it's 1 wire, put it in neutral, pull the wire and check for continuity to ground
if it's 2 wires, put it in neutral, pull the wires and check for continuity post to post
cgmartine
Jun 9, 2018 06:58 PM
Ron750
General Topics/Tech Tips
Jun 11, 2015 11:43 AM
nchogfan
Dec 2, 2013 08:08 AM
Leda1316
EVO
Jan 5, 2008 03:09 PM
ultraclassicrider
Feb 15, 2007 12:52 AM
