Intermittent neutral light
Old Jun 8, 2015 | 06:50 AM
Ron750's Avatar
Ron750
Default Intermittent neutral light
On my 2003 FLHTCUI, the N light is frequently, but not always, not coming on when in neutral. I have had this happen before, but rarely.
Now it is frequent. I did a search and some threads said it could be the ignition relay.
Everything else works fine, and no problem shifting into neutral.
Any ideas?
Old Jun 8, 2015 | 09:11 PM
Ron750's Avatar
Ron750
Is there somewhere to post technical questions where people answer? Should I post it in the touring section?
Old Jun 9, 2015 | 09:50 AM
dhowe's Avatar
dhowe
2nd Gear
Hey, I am not an expert on this, but I would start by checking the wires from your neutral switch to see if there is a break. It may be something that looks fine, but the wire is broken inside the shielding so try moving and wigling the wires while checking the light. Again, I don't know how that model is set up, but it is probably a set of wires from the transmission area. Also, check the connectors at the light itself, sometimes the vibration will cause things to break, and they may look like they are still connected, but they are not. Let me know what you find.
Old Jun 10, 2015 | 03:39 PM
enodrano's Avatar
enodrano
The neutral switch is a sensor that detects when your shifter is in the neutral position. It's located on your transmission case and monitors the internal gears. It probably needs to be replaced (Easy/Cheap fix). However, that's how it is on newer bikes. Yours may be externally monitoring the shifter lever. If that's the case then the switch is either dirty, misaligned, or needs to be replaced.
Good Luck!
Old Jun 10, 2015 | 09:44 PM
Ron750's Avatar
Ron750
Thanks.I found the neutral switch, on the transmission. The connections look OK. I am going to check under the fairing.
Old Jun 11, 2015 | 11:32 AM
dhowe's Avatar
dhowe
2nd Gear
If the connections and wires are good than I would agree with enodrano and replace the neutral switch.
Old Jun 11, 2015 | 11:43 AM
Scrmnvtwins's Avatar
Scrmnvtwins
The neutral switch may be dirty or bad, try removing and cleaning and see if you can operate the neutral light with the switch before you put it back in.
balloo
Jun 24, 2019 06:49 PM
nchogfan
Dec 2, 2013 08:08 AM
SBFD8
Jun 29, 2009 10:18 AM
ultraclassicrider
General Topics/Tech Tips
Feb 15, 2007 12:52 AM
Jimbo192
Sep 23, 2006 07:22 PM
