Neutral light stays on
Old Feb 7, 2007 | 10:11 AM
ultraclassicrider's Avatar
ultraclassicrider
Stage III
Default Neutral light stays on
I have a 2007 Ultra Classic. When I ride for about 2 hours or more the neutral light comes on and stays on regardless of what gear I'm in. My harley shop says they have never seen this problem. Anyone know anything about this?
Old Feb 7, 2007 | 10:22 AM
rh8234's Avatar
rh8234
Default RE: Neutral light stays on
I would try replacing the neutral switch. Sounds like it's busted - stuck with the contacts closed. I forget - Does the neutrel switch have just one single wire on it? If so, it is probably a ground wire and that could be shorted somewhere between the switch and the neutral light.
Old Feb 7, 2007 | 11:09 AM
PosseRider's Avatar
PosseRider
It has 2 wires to it
Old Feb 7, 2007 | 12:15 PM
dert's Avatar
dert
If its an '07,warranty...take it to dealer and let them fix it.
Old Feb 7, 2007 | 12:17 PM
rh8234's Avatar
rh8234
Pull both wires off. If light goes off, jumper between the two wires. Light should come on. If the light is off with the wires pulled off the switch and goes on when you jumper between them, I'd try replacing the switch.
Have you removed the switch recently? If so, I believe the bike must be in neutral when reinstalling it so it will calibrate properly.
Old Feb 12, 2007 | 03:46 PM
HogBoy's Avatar
HogBoy
My '07 RKC has the same problem. Bad switch...dealer is just waiting for the part to arrive. They've seen this on several '07 models.
Old Feb 15, 2007 | 12:52 AM
Oldtimer of NM's Avatar
Oldtimer of NM
Could be a bad switch.
Could also be the switch isn't screwed in to the right depth and heat expansion is tripping it. Remove the switch, plug it back in and turn on the ignition. If the light comes on, the switch needs to be screwed in a little bit more than it was. If the light stays off, it needs to go in a little bit less. All depends on whether the newer bikes have a dent or a bump to trip the switch.
nchogfan
Dec 2, 2013 08:08 AM
Thomo_Baca
15
Jan 8, 2012 12:24 AM
yso191
Sep 13, 2009 09:09 PM
stevepacman
May 24, 2008 12:24 PM
Harley Dad
Jul 27, 2005 12:47 AM
