Neutral light on when too hot
Old Jul 27, 2005 | 12:19 AM
Harley Dad's Avatar
Harley Dad
Default Neutral light on when too hot
I have a 00' FLHRCI with 11500 miles on it. I noticed that when the bike gets really hot sitting in traffic, the green neutral light flickers or stays on steady on any gear. has anyone experience this problem? It just started doing it, I'm also running full synthetic oil. [sm=dontgetit.gif]
thanks
george
Old Jul 27, 2005 | 12:24 AM
Markcuda's Avatar
Markcuda
Default RE: Neutral light on when too hot
My neutral light went south, had the dealer put in new bulb, that was not the answer.
I had them put in a new neutral switch and problem solved[8D]
The switch was only $15.00
Old Jul 27, 2005 | 12:30 AM
Harley Dad's Avatar
Harley Dad
thanks, i'll give that a try
Old Jul 27, 2005 | 12:47 AM
HDF Tech's Avatar
HDF Tech
If you disconnect the wire at the switch, you can rule out the wiring in the harness as a source of the problem if the light does not go on, then it points to the switch itself.
Dazzauk
EVO
May 9, 2016 02:36 PM
nchogfan
Dec 2, 2013 08:08 AM
kingultra
May 24, 2007 10:45 AM
ultraclassicrider
General Topics/Tech Tips
Feb 15, 2007 12:52 AM
Jimbo192
Sep 23, 2006 07:22 PM
