Fuel Hoses
Old Jun 6, 2015 | 09:58 AM
roadbuilder's Avatar
roadbuilder
Smile Fuel Hoses
Need the two in-tank fuel hoses for my FLHTCUI and when I sent the tank to rad shop for reline they cut the fitted ones off. Question is can I get away with buying good quality generic hoses and just use them or are the stock fitted hoses necessary??
Old Jun 6, 2015 | 10:54 AM
Apendejo's Avatar
Apendejo
Go with the stock hoses.
Old Jun 6, 2015 | 12:41 PM
roadbuilder
Smile Fuel Hoses
Will do and thanks.
Old Jun 6, 2015 | 12:48 PM
Stiggy's Avatar
Stiggy
Not true! Go to NAPA and buy R-10 submersible neoprene hose. It's the same stuff any manufacturer uses in a fuel tank with a pump inside.
It'll still cost you $30 for a foot, but cheaper than the Dealer by a long shot.
Just remember, it's gotta' be "R-10".
Old Jun 6, 2015 | 03:50 PM
Apendejo's Avatar
Apendejo
If you already have the clamps and crimper tool that would work.
I would not use regular hose clamps inside the tank, but that's just me. The stock lines are shrink fitted to barbed fittings.
Also be aware if you make the hoses too long they will rub on the inside of the tank tunnel eventually pin-holing and causing the bike to run erratic. Do't ask me how I know.
Sometimes its just better to pay the OEM price than to embark on a science project.
Old Jun 7, 2015 | 09:49 AM
roadbuilder
The problem is getting the right hoses in a timely manner, may have to go with the R10 hose then order the hoses from Harley. Either way, thank you guys for your input. Always is a plus...
Old Jun 7, 2015 | 10:00 AM
im's Avatar
im
The R-10 hose is rather thick and should have much less of a chance of developing a hole than the factory hose.
Fuel injection style clamps should be fine and are a step-up from worm clamps.
Old Jun 11, 2015 | 10:48 PM
roadbuilder
Job all done, thanks to all for the good advice!!!!
Whiskyjock
Jun 7, 2014 05:24 PM
12hdrk
Jan 15, 2014 09:31 AM
jaxx1972
Jan 4, 2011 04:46 PM
mulch63
May 11, 2009 07:14 AM
Kikilee
Oct 26, 2006 04:25 PM
