I have the same Rox Risers, will need to cut some cable ties to get enough slack up thru triple tree. I just couldn't get enough stretch to get them on. I don't see a way to cut the ties unless I remove the gas tank. ugh. Am buying a service manual hopefully today...........thx for the share
Frank, thanks for the post and the pictures. I ordered the same risers today. Went and took a look at the clutch cable and it looks VERY tight. Can you still turn lock-to-lock without the clutch cable interfering, especially to the right?
Yes the clutch cable is the shortest and it take some fanageling to get the risers installed because of this. I did not disconnect anything except for the clamp holding the handlebars. Since the Rox are two pieces, it would have been nice to have a second pair of hands to help hold and tighten in order to line things up. It was a matter of snug this up, than clamp than, and snug up some more. Had to leave all of the final tightening untill all in place, and after those hard to reach lower bolts as I discussed were tightened down all the way.
Once all in place, no problem going lock to lock. Be mindful, the Rox risers, if pulled too far back will hit the speedo console. MIne just clear by a hair.
