2018 Softail (Heritage) battery problem
Old Jul 10, 2018 | 11:02 PM
Prot's Avatar
Prot
At least one person has had a bad voltage Regulator on a new Heritage
Old Jul 10, 2018 | 11:09 PM
stinkerbill's Avatar
stinkerbill
Thanks all.
The dealer told me that yeah, dropping to 12.6v when left off is normal, so I'll try not riding for a few days and regularly check to see if the voltage keeps dropping.
They did say they've had a few of the 2018 Softails with similar issue, but that mine's the first that's come back twice. Apparently Harley are aware of the issue, but for now there's no 'fix'
I'll keep this thread updated, good or bad.
Old Jul 11, 2018 | 05:58 AM
Another Old Timer's Avatar
Another Old Timer
Hate to say it, but have never taken the Fob out of the saddle bag since I picked the bike up at the end of last October, Never had an alarm installed, but the lights flash if you disturb the bike. Now at 6,400 miles and gets better every time I ride it.
Old Jul 11, 2018 | 06:57 AM
stinkerbill
ok, 24 hours later and the bike's still holding 12.75v
Interesting point about the key fob - my spare is in my office, which although 2 walls away from the bike, is only about 5m.
Anyhoo, I'll keep checking on the voltage, but maybe the reset the garage did has worked
stinkerbill
Originally Posted by kenny55
12.7 VDC is about normal for a battery sitting idle with engine off. This represents 100% charged. When you start your bike it should read the output of the voltage regulator which is approx. 14.1 VDC.
High CCA should be a good thing. That just means you can provide more to the starter and other electrical systems if needed when you start your bike. Spec for 2018 Heritage says good battery should be 315 CCA.
If you are measuring the voltage when you start your bike you will probably see the voltage drop to about 11 VDC for just a moment, then the engine starts and the voltage regulator drives the voltage to 14.1 VDC
Yeah, once running it's showing a good 14.1v or so.
Old Jul 12, 2018 | 06:18 AM
Phill Thomas's Avatar
Phill Thomas
6th Gear
My dealer phoned and said they can't find an issue. However, as the bike has discharged the battery twice in 900 miles, they are keeping it until they find a reason. They have two Heritage Classics in the workshop with this issue.
The key fob won't receive a signal back from the bike if the engine stop is in the off position. Theoretically everything is isolated with the engine stop switch in the off position. The alarm system has its own battery as it sounds the siren if the main bike's battery is disconnected. I don't know how the alarm circuit is re-charged.
Dropping from 13v to 5.7v in 48 hours, like mine did, is a significant draw on power. If it wasn't intermittent, it should be easy find.
It may take a while to fix as the HD UK tech. wizard is on holiday!
Old Jul 12, 2018 | 06:32 AM
stinkerbill
Definitely keep us posted Phil!
Mine seems to be keeping charge, but I’ll keep monitoring it each few hours for the next few days and note any change
which dealer are you using?
Old Jul 12, 2018 | 09:28 AM
kenny55's Avatar
kenny55
Ask them to put a current meter at the battery terminal and with the bike engine off and ignition switch off ask them what the current draw is. It should be less then a few milli amps. Theoretically it should be 0 ma. To measure the current you have to pull the red lead off the battery and put the meter leads between the positive lug of the battery and the red lead.
If its 0 ma then the bike is fine and you have a bad battery. If its some number greater than like 50ma or something then there's some electrical component within the bike drawing the battery down or the positive lead is shorting to chassis. It should be rather simple to find.
Old Jul 18, 2018 | 02:43 PM
stinkerbill
So, the battery seems to be holding fine - hasn’t dropped below 12.6v and has been left for a few days between rides
maybe the reset worked
Old Jul 18, 2018 | 02:45 PM
stinkerbill
Any update from your end Phill?
