Six Speed for Softtail
Old Jan 28, 2005 | 09:18 AM
randyr's Avatar
randyr
Default Six Speed for Softtail
Anyone out there upgrade a 2000-2005 Softail with a Six-Speed Transmission? was it worth it and how much difference does it make cruising he highways?
Old Jan 29, 2005 | 04:25 AM
sfarson's Avatar
sfarson
Default RE: Six Speed for Softtail
Read a great review of the 6th speed transmission in a recent issue of American Rider. They put it in a Heritage. It isn't for everyone.... cost, some gear whine, and the 88B can be challenged driving it. It will reduce highway RPM's by 300. Not sure this is very much. Works better with a bigger bore bike. Net... while I think H-D's ridden on the highway extensively can use a 6th gear, I think I'll be patient waiting for a factory bike with a bigger engine and 6th gear stock. But this is me.
Old Jan 31, 2005 | 05:06 PM
randyr's Avatar
randyr
Thanks for the input and if all you loose with the 6th gear is 300rpm it hardly seems worth it. Like you, I will wait.
Old Feb 2, 2005 | 12:37 PM
Triple Z's Avatar
Triple Z
We have sold just one 6-Speed gearset for a '01 Softail customer.
He loves it! Not so much for the relaxed cruising in top gear, but for the improved shift quality.
The 6-speed uses a shifting mechanism similar to what's found in the VRSC.
Knowing how the Motor Company does things, I wouldn't expect 6-Speeds to be standard equipment anytime soon.
Maybe a factory-installed option at sometime in the future?
Old Feb 4, 2005 | 09:31 AM
augason's Avatar
augason
I purchased the gear set and have been buying tools for the swap. I have had it apart once and found out the hard way
that my collection of tools was a little shy. I think I have them all now and am just waiting for my ***** to grow again to
tear it apart and go for it. I am excited for the improved shifting and that feeling of wanting to shift around 75 mph to go away.
I will give a break down of the progress and my pit falls when I get the job done. By the way its going in my 03 Fat Boy.
I think I was a little nuts when forked over the dough ($1900) I could use the money know but if we all are not a little
nuts now and then life would be borring.
Old Feb 4, 2005 | 08:38 PM
investorsc's Avatar
investorsc
If you instal the primary gearing set (40200-02 SE Primary Gearing Set $134.95), it will change the primary ratio to 1.7 to 1 from 1.44 to 1. It cuts the overdrive down, but gives you a much closer ratio trans and (allegedly) smoother shifting. It should allow a standard engine bike to maintain a smoother torque curve without the big motor kit (Read that- less spread between each gear)...
My .02
BRUCE
Old Feb 5, 2005 | 02:58 PM
TexasBowhunter's Avatar
TexasBowhunter
Not to sound ignorant but I dont understand what the difference between the gear ratios you just mentioned will do.
Are you saying that I will lose the top in?
Will it be slower in take off?
Will it be faster?
Old Feb 6, 2005 | 02:49 AM
augason's Avatar
augason
Hey Bruce, I get the part about changing out the gear for my over all final drive belt. By changing it to a smaller gear
everything drops down a bit and my final drive ratio would still be better that with the 5 speed and my bike would feel
and for that matter be quicker. What I dont get is how the part you mentioned would help the smoothness of the shifting?
Also what gear are you talking about? Can I change it out while I am swapping the 6 speed gear set? I am a little lost
also and do want to do this right the first time. Thanx in advance for any help you can give me.
Mark
stevieg
Oct 10, 2014 02:29 AM
heritageblue2013
Apr 22, 2013 09:34 PM
95hd883
May 20, 2008 10:03 AM
MAX EVO
Jan 17, 2007 01:16 PM
monkyman
Aug 2, 2005 01:58 AM
