Odometer trip reset
Old Sep 11, 2018 | 04:02 PM
wgarrity's Avatar
wgarrity
3rd Gear
Default Odometer trip reset
Hello my name is Bill and I am looking for a odometer reset for my 1992 harley fatboy. Can someone help me?
Old Sep 11, 2018 | 06:28 PM
Uncle G.'s Avatar
Uncle G.
https://www.ebay.com/itm/Harley-CCI-...-/332040810470
https://www.ebay.com/itm/chrome-spee...gAAOSwwhhbP~Nm
Amazon Amazon
Here are three sources. OEM part number is 67215-89.
Old Sep 11, 2018 | 06:47 PM
wgarrity's Avatar
wgarrity
3rd Gear
Default Odometer reset
Thanks for the reply but I had already checked amazon, ebay, and other entities and no luck. Those ***** are to short.
Old Sep 11, 2018 | 07:12 PM
RANGER73's Avatar
RANGER73
There are 3 different styles. One should work. Check and make sure the shaft that's part of the speedo is in place,If not you're SOL.
Old Sep 11, 2018 | 07:14 PM
wgarrity's Avatar
wgarrity
3rd Gear
That's what I need is the shaft and ****
Old Sep 11, 2018 | 07:20 PM
S.D.M.F's Avatar
S.D.M.F
https://www.ebay.com/itm/Knurled-Sta...arley-Davidson
https://www.jpcycles.com/motorcycle-reset-*****
Old Sep 11, 2018 | 09:23 PM
Uncle G.'s Avatar
Uncle G.
If the ***** I referenced won't work then the shaft the **** mounts onto is missing. The shaft is part of the speedometer and not sold separately. That's the same speedometer as I have (well, had).
Old Sep 12, 2018 | 04:52 AM
RANGER73's Avatar
RANGER73
That's what I was saying. And I think he confirmed, the speedo shaft is missing.
You need a new speedometer then or buy a used one and try to remove that shaft as a replacement.
But I'm not sure if they are replaceable. Maybe someone else knows.
I found this,
http://www.eharleyparts.com/cart/Spe...12-93_67212-93
Old Oct 21, 2018 | 10:33 AM
wgarrity's Avatar
wgarrity
3rd Gear
Default 92 harley fatboy flstf
I have a 1992 fatboy flstf that the horn, turn signals and brake lights don't work. Can anyone help me out? I checked for fuses and could not locate them if any.
Old Oct 21, 2018 | 05:38 PM
RANGER73's Avatar
RANGER73
Look under the console the speedo and ignition is on.
