Spokes and Cleaning
Old Sep 16, 2018 | 09:21 AM
sumncguy's Avatar
sumncguy
Default Spokes and Cleaning
I know the spokes are going to be a pita to keep clean. But I bought this bike because the spokes and wide whites make the bike pop.
Anyway .. Ive read a bunch of the threads.
Im thinking .. rinse, simple greeen, rinse, blow dry, hand dry. Then Polishing with White Diamond. ... dont know if I have the patience to do every spoke individually though. MIght have to bite the bullet and pay someone.
Old Sep 16, 2018 | 09:59 AM
FrankEV's Avatar
FrankEV
When you do, you have to get up on a stand so you can rotate the wheels. Even then, getting to the spokes behind the rotors is one PITA.
The stuck on road grime does not come off with out some elbow grease (that is actually wide shoe laces dipped in crome polish and worked back and forth on each spoke). After a good scrubing, rince and dry...wipe each down with some never dull.
Better figure a good 4 hours and sore fingers to get it done well.
You know, the idea of paying someone to do it is starting to look better and better, but I betcha I could not afford what it would cost.
Old Sep 16, 2018 | 11:07 AM
martin10's Avatar
martin10
Best solution I have found is to forget about them. I clean the rims ever few rides but don't worry about the spokes. During the winter I will clean them, but other than that its not worth the effort to me.
Old Sep 16, 2018 | 01:20 PM
Bone Doc's Avatar
Bone Doc
It is a pain in the *** for sure. When I detail the bike, the spokes and whitewalls together easily take a couple of hours. The rear wheel is a bear because you have the rear sprocket on one side and the brake rotor on the other. It takes patience, time and beer.
Frank gave excellent advice. I use a wide shoelace as well.
Old Sep 16, 2018 | 01:58 PM
PA1195's Avatar
PA1195
Get wheel spoke brush. Use as is or remove handle and insert metal stem in battery drill motor. Raise bike on lift under engine so tires can turn. Brush the dirt away after soaking with cleaner. I use whitewall cleaner: https://www.blackmagicshine.com/tire...-tire-cleaner/ Then wash bike and blow dry with battery (Dewalt brand) or gas leaf blower.
Old Sep 17, 2018 | 09:17 AM
CaptainKirk's Avatar
CaptainKirk
I just use a spray-on cleaner like s200, let it sit and hose it off. As long as you do it often enough, the chrome spokes should be fine. What I can tell you as someone who had WW for many years, nothing cleans them like Mr. Clean Magic Eraser and Bleche White. Just rinse and rinse and rinse as quickly as possible. I have a 16 Heritage with blackwalls now and I'm often tempted to put WW on it...... Nothing like them for adding pop to the bike. Good luck!
Old Sep 17, 2018 | 01:23 PM
PA1195's Avatar
PA1195
That Bleche-white cleaner I linked can be rough on bare aluminum and paint. See their ad: https://www.blackmagicshine.com/tire...-tire-cleaner/ I like to spray it on the bottom of the tire only and then rotate the tire to cover the rest. Keep it away from nearby stuff and rinse off soon after scrubbing.
S200 acts similar and can stain some so test before using. Simple Green is tough on bare metal like aluminum too.
Turret_plug
Feb 10, 2014 10:25 PM
Sharpie
Wheels/Tires
Jan 20, 2014 11:21 PM
Sportrider79
Apr 19, 2012 05:44 AM
arsonist
Feb 11, 2009 11:06 AM
Crazier Steve
May 22, 2008 10:29 AM
