18 Heritage soft lowers?
Old Sep 28, 2018 | 09:57 PM
Yzzyx's Avatar
Yzzyx
Default 18 Heritage soft lowers?
If you add engine crash bars to a 18 Heritage, will soft lowers fit on it?
Old Sep 29, 2018 | 12:17 PM
PA1195's Avatar
PA1195
I've been meaning to see if pre-18 lowers fit too. They may but I need to drive to the shop and try some. Might take some fitting around the oil cooler and lower frame. Temps in the lower 20's this AM so they would be nice.
Old Oct 3, 2018 | 08:41 AM
Yzzyx's Avatar
Yzzyx
I ordered these:
https://www.leadermotorcycle.com/col...8-standard-bar
Old Oct 3, 2018 | 08:52 AM
r0de_runr's Avatar
r0de_runr
The Genuine HD Soft Lowers from previous years will fit the bars, but the buckles on the straps will not fit between the frame and the oil cooler. I had to cut the male buckle off and use wire ties to hold it on. Invisible to the eye unless you get down and inspect how they are held on.
Old Oct 3, 2018 | 01:55 PM
PA1195's Avatar
PA1195
I've had Desert Dawgs before. Good product and thanks for the info guys.
Old Oct 19, 2018 | 08:49 AM
Yzzyx's Avatar
Yzzyx
Originally Posted by Yzzyx
I've ridden my Desert Dawg soft lowers for about 2K miles.
+ They look nice.
+ They are stitched very well.
+ The snaps and top strap are easy to attach.
+ They block the wind.
- They are a bit expensive.
- They don't block as much wind as the HD touring soft lowers
- The bottom velcro attachment thingies are a bit weird to work with.
YMMV
Callahan86
Mar 9, 2022 03:16 AM
thereal142
Apr 5, 2017 09:13 PM
Sparks200
2014-2024 Touring Models
Jun 26, 2014 03:30 AM
FL-kruzen
Touring Parts
Dec 2, 2011 03:01 PM
Nellybelle
Oct 20, 2008 09:40 AM
