Water in the transmission
Old Jun 30, 2007 | 11:21 PM
petersbr's Avatar
petersbr
Default Water in the transmission
I have had a 2007 Night Train four about 4 months. First service, no problem but now at the second service (around 7000 mile) the mechanic found water in my transmission fluid. He said there was a breather tube under the bike that might have let it in. I have riden in the rain a couple of times and I did wash it off with a hose. Has any one else had this proablem? Any sugestions on how to fix it?
Old Jul 1, 2007 | 12:48 AM
05 HD Deluxe's Avatar
05 HD Deluxe
Default RE: Water in the transmission
I have heard of it hapening from the shop that services my bike. It may have been located in such a way that water that was coming up off the back tire was entering the hose.
Old Jul 1, 2007 | 08:53 PM
rbabos's Avatar
rbabos
That's odd. My 07 custom has about a 4" moulded hose that comes out of the top of the tranny, over to the right side and then bends down at the nuetral switch. At first I thought water might puddle there and when the tranny cools off the vacume would suck water in, but further checking showed that water won't sit in there and the end of the hose if about 1/4" above the case.
Ron
Old Jul 3, 2007 | 08:57 PM
mori55's Avatar
mori55
I had the same problem , it comes from the clutch adjuster boot holding water , then running inside tghe cable to the transmission. I pulled the boot back so the water would drain out , solved the problem.
STREETB0BT0NY
Apr 15, 2018 08:15 PM
Kbs631
May 19, 2016 06:35 AM
Roddyboyz
Nov 12, 2010 02:36 PM
relli
Oct 1, 2007 06:12 PM
Tman
11
Aug 31, 2007 10:52 PM
