Batwing on a Fat Boy and wind buffeting
I have buffeting so bad I can't stand to ride the bike anymore. I started with a 6" plain windshield and the bike was seriously unrideable above 60 mph. I tried a set of the fork mounded wind deflectors from Memphis Shades. They didn't help, but depending on how I mounted them I could make it worse at low speed.
Next I bought a set of Harley fangs. I hate the looks, but I figured I would learn to like them since everybody says they work. They helped, but didn't cure it. A 100 mile ride left me with a screaming headache and no desire to try that again.
I then bought a Klock Werks 5" flare windshield, again after reading so many say it solved the problems. I mounted it with the fangs still installed and it was better above 70 mph, but it was way worse at about 40 - 60 mph. Still not usable at highway speed either. I took the fangs off and ran just the Klock Werks windshield. It is better without the fangs, but in no way is the bike ride-able for any length of time at highway speeds.
I then drilled another set of holes in the original flat windshield so I could mount it an inch lower and tried it. This was better, but in no way good enough.
I put the fangs back on with the lower windshield and this is the best combination. Some buffeting at 45-60 and 70 mph is better than 60, but it still isn't good and there is no way I see myself trying a ride of even a couple hundred miles with it like this.
I am about done throwing money at this trying stuff to figure it out. Have any of you run into this? What did you do to work through it?
So unless you find the person that's done it before you, it's anyone's guess what will work the best and unfortunately it's almost certainly going to be a trial and error process until you happen upon the best solution for your bike. Good luck!
The time, expense and effort is the primary reason I'm leaving my Fat Boy naked. I've found that with the type of riding I now do, with it almost exclusively under 60, I don't need a shield and the lack of buffeting makes the ride quieter and much more enjoyable.
Nests to the headlight/bars exc.
I have a Deluxe with a batwing (no idea who made it {used}).
I did quite a few mods to the inner shell and a few to the outer (the reason i bought used).
I also cut and re-drilled the mounting brackets moving the fairing down & closer to the shocks/handle bars.
The ones I have seen fit so sloppy it is no wonder there is wind issues with allot of them.
When I brought mine home I could fit a tape sideways over the top of the head light.
Now mine sets on the headlight (foam in between).
I do get some wind buffeting (similar to my old 01 FLHT.
The sloppier the fit the more wind you will get through all those gaps.
With the batwing I original had some buffering but added the Memphis Shades "FLH" Wind Deflectors (they dont mount to the forks but under the "wings of the fairing) it solved the problem for me.
https://memphisshades.com/collection...ind-deflectors
2. With the large wind shield , very little buffering but no hand forearm protection. I like the nostalgic look and definitely works well at lower speeds (under 50 mph)
3. With the MS Batwing the overall best wind protection, I had a little buffeting until I mounted the defectors but nothing now form 0-75 mph.
I also have owned a Road King and a Road Glide. The amount of buffeting depends on you size and riding position.
