1999 softail d02 error code help
Old Apr 3, 2019 | 10:15 PM
Will Swan's Avatar
Will Swan
6th Gear
Default 1999 softail d02 error code help
Starts and runs fine then...
Battery drains when running and will stall even at high RPM's
Will start when cool
Replaced the crank case speed sensor
The badlands load equalizer fried because the wire was pinched against the frame( this is a two wire load equalizer that was hooked up for the rear lights )
Am I discharging or something OR did something else fry when the load equalizer did? I DID NOT replace the load equalizer
ERROR CODE d02 - Speed sensor power output shorted high or open
Old Aug 25, 2022 | 07:54 PM
tonelop's Avatar
tonelop
4th Gear
Good evening, I would like to know how you did to solve this error code. I have the same
thank you
bcherry
Jun 27, 2016 10:05 AM
AKFXD
May 16, 2016 10:46 AM
atrailblazer
EVO
Feb 20, 2014 02:48 AM
kcatz
Jun 5, 2010 07:11 PM
codyshop
Jul 23, 2009 10:43 PM
