Deluxe Fuel gauge always full
Old Apr 22, 2019 | 07:35 AM
CrazyBones's Avatar
CrazyBones
Default Deluxe Fuel gauge always full
I have swapped the fuel gauge out with a different one (had tons of extra parts from a previous wrecked bike) and the gauge still reads full. I know I can use the odometer and avoid running out of fuel but call me crazy, I just like seeing a working gauge. Is there a way that the float can be adjusted? I have seen a lot of folks having this issue but haven't heard of any options to correct it.
Old Apr 22, 2019 | 07:41 PM
hattitude's Avatar
hattitude
What year bike.......?
Old Apr 22, 2019 | 10:03 PM
CrazyBones's Avatar
CrazyBones
Sorry its a 2005 deluxe FLSTNI
Old Apr 22, 2019 | 10:32 PM
S.D.M.F's Avatar
S.D.M.F
How long ago did you swap it out? It can take a few tanks of fuel for it to re-calibrate.
Old Apr 23, 2019 | 12:17 AM
CrazyBones's Avatar
CrazyBones
it was a while ago, maybe a week? so had a few tanks through the bike since then..
Old Apr 23, 2019 | 03:56 AM
j33ptj's Avatar
j33ptj
Check your conenctions, the fuel sender is a rheostat that will send a "full signal" when there is a high resistance in the loop. When the floats goes down the resistance in the rheistat reduces so the gauge starts moving down (it now recieves a voltage). If your connection is no good, the gauge receives no voltage to move the needle and will therefore read full all the time.
RJ
Old Apr 24, 2019 | 07:39 AM
CrazyBones's Avatar
CrazyBones
RJ
confirmed all connections were solid. at least from where the gauge itself connects to the wiring from the bike. Again this is the second gauge with same result, which leads me to believe its the float itself
Barz
Aug 24, 2021 01:23 PM
jcdavis157
Apr 10, 2018 09:40 PM
douggyjb
Apr 20, 2012 08:01 PM
FireFighter25
May 17, 2011 01:37 PM
cws176
General Topics/Tech Tips
Apr 10, 2006 05:19 PM
