Stripped engine oil drain plug.
Old Jul 17, 2019 | 03:55 AM
rjgordon0's Avatar
rjgordon0
6th Gear
Default Stripped engine oil drain plug.
Hi, can anyone please tell me the thread size on the engine oil drain plug for a 2006 FXSTC 1580 ?
Thanks Bob.
Old Jul 17, 2019 | 08:41 AM
Will Belden's Avatar
Will Belden
Couldn't find FXSTC, but I'm pretty sure these are all about the same, at least from the same year for the Softail series.
https://www.jpcycles.com/product/601...ank-drain-plug
Old Jul 17, 2019 | 08:59 AM
hattitude's Avatar
hattitude
I believe your bike uses the Drain Plug # 60328-98B, which has 1/2 x 20 threads.....
Old Jul 17, 2019 | 09:12 AM
PlasdoSport's Avatar
PlasdoSport
Just did my first oil change in my "new to me" 2003 vrsca last night. The previous guy used locktite on both the drain plug and the filter. If the garage walls could blush, they would've been rosy from all the new cuss words. I was starting to "round over" the 17mm hex bolt when it finally gave way.
Old Jul 17, 2019 | 09:22 AM
470004's Avatar
470004
Agree.
Old Jul 17, 2019 | 09:28 AM
Jackie Paper's Avatar
Jackie Paper
Harley uses a 1/-20 thread special MS fitting o-ring seal. That o-ring seals in the bevel and not on the face. Any attempt to helicoli or insert repair is a pain. You no longer have a bevel.
As designed, Harley's plug goes metal to metal on the face and locks up. That fine thread is easy to strip with oil on it. It just needs a bump to stay tight. Torque to speck after a lot of oil changes will wear it out .
Interesting to see what you come up with. Harley should have an oversize self threading plug. Don't think so. AutoZone and Advance does but you will end up with a face gasket. That sucks except on the balanced engines.
Old Jul 17, 2019 | 02:18 PM
09fitz's Avatar
09fitz
I had to do that once as a young man on the first oil change on a brand new bike. One of those life lessons.
burchis
Jul 3, 2020 07:05 PM
PhatBoyHigh
Nov 25, 2015 11:11 AM
barrywilson
Oil Archive (no new posts)
Nov 23, 2014 03:58 PM
rattlebones
Feb 23, 2010 03:41 PM
HDSAE60
Aug 12, 2009 08:58 PM
