Removing passenger back pad
Old Aug 18, 2019 | 08:57 PM
clancaster23's Avatar
clancaster23
Default Removing passenger back pad
'17 Heritage, I want to swap out the stock passenger back rest pad with another one that's bigger and has studs on it. I'm thinking the rear badge emblem thing that covers up the top bolt that holds the pad on is attached with double sided tape. I have not been able to find a new one to put on incase I ruin it while taking it off. Is the only way to get to the bolt is to remove this badge? Anyone know where I can get a new badge to put on incase I ruin this one?
Old Aug 18, 2019 | 09:22 PM
QC's Avatar
QC
Use a heat gun to soften up the tape glue and use a putty knife to gently remove it. Get some double sided mounting tape a your local auto parts store to remount.
Old Aug 19, 2019 | 08:36 AM
Will Belden's Avatar
Will Belden
Yep, heat gun (even a hair dryer will work). Then there's two screws from the frame to the pad. (I say this, but mine is a 16, but probably same setup.)
When you're ready to put it back on, just hit it with the hair dryer again, get it nice and gooey and slap it back on there. I've done mine three times (added some "arms" to the seat for the wife for a while). Then had to re-drill the holes in the arms to make it more level, then eventually took it off.
I haven't had even a whisper of it falling off, and I live in Texas!
Old Aug 19, 2019 | 08:41 AM
Pyro451's Avatar
Pyro451
Debadging my car I used dental floss to cut the adhesive behind the badge. I expect fishing line would work even better. Just be sure to fashion a garrotte (or use one you already have) to avoid cutting into your fingers.
Old Aug 22, 2019 | 11:17 AM
RANGER73's Avatar
RANGER73
Fine fishing line, nylon string or dental floss.
OR
a Thong works sometimes in a pinch.
longrides
Jan 3, 2015 11:58 AM
markkoby
Nov 30, 2012 05:01 PM
chateau
Nov 21, 2011 10:47 AM
HDV-GLIDE
Touring Parts
Jul 3, 2011 09:34 AM
dkpawlowski
Apr 6, 2009 11:39 PM
