TPS Ohms Readings
Old Oct 2, 2019 | 07:12 PM
Prof Rene's Avatar
Prof Rene
Default TPS Ohms Readings
Hey guys,
I have an 06 Softail and I think the TPS might be dying. I cannot find the ohms reading numbers that it should have. I have found voltage, but not Ohms. I am not seeing a problem with the sweep of the TPS, instaed I am having a low idle and it is sputtering and dying at the light.
Old Oct 4, 2019 | 01:40 PM
Oldgreazer's Avatar
Oldgreazer
Default Low idle
You may need to clean your idle air control
Old Oct 4, 2019 | 01:44 PM
76_shovel's Avatar
76_shovel
Typically the Throttle position sensor is checked via voltage readings.
Old Oct 4, 2019 | 02:44 PM
Prof Rene's Avatar
Prof Rene
I cleaned it already and I found a dead spot on the TPS. When I swap the tps I will remove and clean the IAC better.
Scrappy1818
Jul 16, 2014 08:07 AM
sparkplug619
Jul 15, 2012 12:52 PM
MNFB70
Aug 13, 2011 06:26 PM
masterblaster
May 26, 2011 02:29 PM
Bigwillie
Jun 5, 2010 12:56 PM
