06 Deluxe Charging System
Old Jul 16, 2014 | 04:14 AM
Scrappy1818's Avatar
Scrappy1818
Default 06 Deluxe Charging System
Been through 2 stators and regulators in the last 6 months. Been about a month since I put the last pair on. Bike seems to be running fine now but pulled my codes this morning just to see if anything showed and I am still getting a low voltage DTC popping up. No check engine or batt light though. I put a brand new battery on it when the first stator and regulator burned up. Here are the 2 codes that were there today:
U1097 Loss of Speedometer Serial Data to ECM
P0562 Battery Voltage Low
I tested for a direct draw and it was negative. Any help is appreciated.
Old Jul 16, 2014 | 08:07 AM
chrisj49's Avatar
chrisj49
Guessing you have done this, but check your grounds thoroughly.
Does your check engine come on for eight seconds, telling you you have a stored code, after your turn the switch on? It takes 50 starts to clear the stored code, I think.
Low Voltage triggers when the voltage is low for 5 minutes. Check the voltage across the battery terminals at idle. It should be around 13.5, and should jump to 14+ if you double the idle. If it isn't you might have a stator or regulator problem. If it is within range, it sounds like you have an intermittent problem, so I would look at connections.
You also shouldn't be frying stators and/or regulators like you are, which suggests a short.
kevjo
Sep 10, 2018 06:51 PM
namato1
May 5, 2014 04:56 PM
d-streetglidr
Jun 13, 2013 11:41 PM
TestFlyer
Aug 7, 2010 05:42 AM
DarkManC
Jul 10, 2009 07:24 PM
