HD chrome heel/toe shifter peg retrofit
Old Oct 14, 2019 | 03:57 PM
MidlyfeHDcrysess's Avatar
MidlyfeHDcrysess
Default HD chrome heel/toe shifter peg retrofit
Hey friends! I have a question about changing out my stock shifter pegs on my 03 heritage softail For a nice set of chrome and rubber bar&shield set I recently purchased at the local HD dealership. Kit includes 1 shifter peg body,1 button head cap screw. But my dilemma here is the stock rubber peg attached to the arm appears to have no tool application visible for removal? I thought I'd be applying a torx or Allen wrench for quick retrofit but not the case here! Has anyone else run into this and how did you proceed without causing damage to original pegs and levers? Any advice or suggestions are appreciated and welcomed! Footnotes: Any upgrades I do I always keep original stock parts in the best possible conditions for down the road nostalgia. Thanks again in advance!
Old Oct 14, 2019 | 05:45 PM
hattitude's Avatar
hattitude
The older pegs I have added/replaced never used a tool. The bolt is captured in the rubber peg.....
As long as the installer didn't use red locktite, and your rubber is in good shape, you should be able to remove them without damage...
Use a strap wrench on the rubber peg, or wrap the rubber peg with a rag and then use pliers/channel locks to unscrew it....
The newer pegs use an allen wrench on the end of the peg....
Old style pegs:
New style pegs:
Sammi
Dec 18, 2015 06:20 AM
k1768
Jul 5, 2010 01:00 PM
southernhiker
Aug 12, 2009 01:18 PM
Aces N Eights
Aug 8, 2007 05:03 PM
rvisdew
Dec 19, 2005 06:43 PM
