Removing the dash panel on 2010 Heritage
Old Oct 24, 2019 | 09:22 PM
Man In Black's Avatar
Man In Black
Default Removing the dash panel on 2010 Heritage
Should be easy , remove the acorn nut and the odometer **** and lift up . But mine seems stuck on like weld . I don't want to force anything , is there something that I am missing ?
Old Oct 25, 2019 | 04:24 PM
Dehammer's Avatar
Dehammer
If I remember right.....that is the same dash as on the Slim, the skull like dash.
The acorn nut is the only thing keeping it on. You shouldn't have to remove the ODO button. The gasket is just a soft flexible strip, not anything formed, but it does have an adhesive holding it to the dash. It's just stuck to your tank. I would spray the rubber with some WD40 and it should pop off.
Old Oct 25, 2019 | 06:23 PM
Man In Black
Thanks , I'll give it a shot .
Old Oct 27, 2019 | 08:32 AM
Man In Black
I sprayed it with WD-40 and let it sit overnight and it popped right off after soaking . Wow ! that thing was really bonded on there . For a bike with really low miles the rear gas tank bolt was gaulded in the threads too . Had to heat with a hair dryer to soften the lock tight and it still beat up the bolt . Seems like they are using red lock tight !
Peirce1970
General Topics/Tech Tips
Dec 26, 2015 02:03 PM
anyaneeeze
Jun 10, 2015 11:35 PM
Nightrider2
Sep 17, 2010 08:44 PM
4 inch pistons
Exhaust System Topics
Sep 11, 2010 07:24 PM
BIG Y 2014
Jan 7, 2008 08:11 AM
