AIRFX
Old Aug 9, 2007 | 08:50 PM
grzly's Avatar
grzly
Default RE: AIRFX
thats a shame. hoping to have a little bit of extra clearance if i got some twisties to get through. but otherwise mostly for beefing up the bike for extra load
grzly
ORIGINAL: mori55
If you raise the bike only and inch or two it will ride rough.
Old Aug 10, 2007 | 08:50 AM
97FXSTSB's Avatar
97FXSTSB
Default RE: AIRFX
Thanks for the info on this system. Will defintely consider it. Post a follow-up on the system after awhile. Let us know if any leaks develop. I want a system that you can air up to the desired height and it will stay there.
Old Aug 10, 2007 | 02:58 PM
mori55's Avatar
mori55
Default RE: AIRFX
You have to remember if you take air out of airshocks it's gonna ride rough, it will have no spring. Just the same as if you put to much air in, it will have no spring to it. It does get higher than stock, so you do get extra ground clearence for the twisty's.
Also alot depends on your weight.
Old Aug 10, 2007 | 03:31 PM
grzly's Avatar
grzly
Default RE: AIRFX
Thanks Mori for the feedback
i will go ahead and install. for 2 up riding should be perfect
grzly
NightTrainn03
Air Suspensions
Jan 26, 2015 01:35 AM
Chopper Dave
Air Suspensions
60
Sep 3, 2010 12:25 PM
WildThang
Mar 13, 2010 08:37 PM
BlkNyt
Mar 24, 2007 12:22 AM
UltraScoot
Sep 11, 2006 08:48 PM
