Oil check valve
Old Jan 21, 2020 | 09:17 PM
Cadipietro's Avatar
Cadipietro
2nd Gear
Default Oil check valve
So I just installed Andrews 57H cams in my 2015 fatboy lo. Ran it for about a minute the shut off to check the oil and a blast of air hit me. I read that the check valve us causing that. Can some1 point me to where it is?
thanks
Chris
Old Jan 22, 2020 | 12:42 PM
XARAN's Avatar
XARAN
Its located in the cam support plate
https://www.hdforums.com/forum/oil-a...ve-repair.html
https://ertproducts.com/wet-sumping
Old Jan 22, 2020 | 04:48 PM
hattitude's Avatar
hattitude
Originally Posted by XARAN
OP has a Twin Cam...
I know your second link is an oil pump for a shovel head, EVO engine, not a Twin Cam... and I believe your first one is about a shovel/EVO also...
The Twin Cam has a pressure relief valve in the cam plate, but no check valve that I am aware of....... Certainly no ***** to seat, the pressure relief valve is a cylindrical style plunger... Obviously if it was missing the spring/plunger or they somehow were damaged it could cause problems... but most problems with the pressure relief valve are related to low oil pressure (by-pass opens too early)...
As I understand it, in a Twin Cam:
Oil leaks back into the sump when engine is off (some call dry sumping), due to scavenge gerotors out of tolerence, damaged scavenge gerotors, or a scored oil pump body.
They wet sump (fill the sump while running) due to a pinched or missing o-ring on the oil pump to case...
The build up of pressure in the oil tank is due to excessive blow-by by worn/unseated piston rings or the umbrella valves in the rocker arm stands are worn or backwards...
I'm always willing to learn, what am I missing.....?
Old Jan 23, 2020 | 11:31 AM
XARAN's Avatar
XARAN
My mistake, I jumped in and grabbed a couple links to try to help out and you are correct I had the evo
You are right on your info, When i upgraded to the SE Hyd kit it and the OE plate have the plunger pressure relief
Thanks for catching it.
bbigman8@yahoo.com
Jun 23, 2019 05:01 PM
Parts Giant
Parts Giant
Apr 26, 2019 09:23 AM
jonneyone
Oil Archive (no new posts)
Jan 11, 2015 08:59 AM
blackhawk dude
Aug 3, 2008 10:46 PM
AK_Hog_Herder
May 6, 2006 08:33 PM
