Deuce fork tube removal from triple tree. NEED HELP!
Old Mar 16, 2020 | 06:44 PM
Tony Pipkins's Avatar
Tony Pipkins
Stage II
Default Deuce fork tube removal from triple tree. NEED HELP!
Changing seals on forks and can’t get the tubes out of the tree. I removed the big torq bolt in the back but fork won’t budge. Deuce has different pinch bolts than a standard Softail Any advice would be appreciated. Thanks
Old Mar 16, 2020 | 07:29 PM
Rustyg500's Avatar
Rustyg500
get a shop manual. The procedure is in there.
Old Mar 16, 2020 | 08:11 PM
misfitJason's Avatar
misfitJason
Undo the top fork caps (the big hex bolts) and undo the lower pinch bolts. Assuming you already have the wheel off. And they will come out
Old Mar 16, 2020 | 08:30 PM
joe40x's Avatar
joe40x
Please forgive some of the miserable old ****s on here.( including me, most times)
I guess it's easier to be an ******* than answer your questions.
Anyway, are you sure you need to remove them from the triple tree?
You could drain them and just pull the sliders off and rebuild from there?
Granted you would have to pull the upper plugs to refill the oil...
Old Mar 17, 2020 | 08:24 AM
Tony Pipkins
Stage II
Default I figured it out
If I had a shop manual I wouldn’t have asked the question on here.
There is not a lower pinch bolt on a Deuce.
The seals could be damaged installing from bottom side that’s why they had to come out of triple tree.
I used PB blaster and a sledge hammer.
Old Mar 25, 2020 | 05:58 AM
misfitJason
There are lower pinch bolts on a deuce
Old Mar 25, 2020 | 09:42 PM
hattitude's Avatar
hattitude
Attachment 601601
It seems like you should get a shop manual.....
PB Blaster.... OK, I get that.
You used a sledge hammer on your forks?
You really should get a shop manual....
Andrewsreed
Nov 7, 2017 09:44 PM
mrjohnsonc
General Topics/Tech Tips
Dec 12, 2013 03:43 AM
eviltwin69
Aug 22, 2013 10:53 AM
Triztyn
May 27, 2008 09:41 AM
tjmac49
Apr 21, 2006 09:25 PM
