Front turn signal help please...
I'm gonna relocate my front turn signals to my forks and some of you gave me alot of helpfull info but I got a Question. I'm kinda a shade tree mechanic but not the best.I don't have a manual to help me with the change over so I was wondering if anybody had a diagram on how to take the wires from the bars and tank. Thanks, David.
When I moved mine I just pulled the wires out of the holders on the handlebars. The holders are not tie wraps and can be pulled out andopened up to take the wire out. Just put the holders back in the bars and your done with that part.
You don't have to disconnect anything that way and there is ample extra wire to reroute them down the back side of the forks to the new location. You will needto use a couple of tie wraps to hold the wire in place. There will be anextra couple of inchsof wire when your done and it canbe tied in a small bundle up under the front of the tank to hide it.
Good Luck
Good Luck
