Rear axle
does that sound right thanks for any imput
Second; if your going to do your own work you need to start with the right tools.
The first tool you need is a service manual.
Yes a service manual is a bit expensive but look at it as an investment rather than an expense.
The service manual gives you the reference and instructions needed to do the work yourself thus saving you money and giving you personal satisfaction.
You didn't state what year or model you have so that's probably needed as some years and models differ from others.
You also didn't state why you want to swap the direction of the axle but that really doesn't matter as it pertains to answering your question.
It doesn't matter which direction the axle is installed.
Matter of fact on my 2009 Heritage the axle swap is required in order to install hard bags.
On my 2009 Heritage (with the axle installed entering from the left) as you are standing behind the bike from left to right;
"axle, swing arm, large spacer, rim, medium spacer, brake bracket, small spacer, swing arm, washer, nut, e-clip"
Forget the name but I will post a picture if you need that.
I cannot envision why switching axle would affect spacers. Don't get them mixed up. Some even have a slight bevel in hole or on OD edge that goes a certain direction.
And torque axle nut with a torque wrench. You are working on something that can get you worst then dead.
In the future, keep track of your parts, it`s easy once you develop the habit.
Put your parts in ziplock or manila bags or envelopes, mark the bags clearly.
Back to you....
