23 on a night train with inverted forks
Old Apr 21, 2020 | 05:38 PM
shattered151's Avatar
shattered151
Default 23 on a night train with inverted forks
Hey, I'm looking to put a 23in front wheel on my 09 night train. What issues am I gonna run into? The bike already has HD inverted forks on it with a 21in front wheel.. I've heard others say the inverted forks have a little rake in them and others said they didn't. Do I need to add rake? And how can I accomplish that with these inverted forks? Thanks in advance.
Old Apr 22, 2020 | 10:48 AM
shattered151
Can I add rake to the trees, or do I need new trees? Do they make trees that will fit my oversized fork tubes?
Old Apr 24, 2020 | 09:56 AM
MCSarge's Avatar
MCSarge
You need to make sure you have enough space between the top of the fender and the bottom of the tree under full compression when you install the new tire. You will also have to check the distance between the fender and the frame on full compression to make sure you can still turn the forks. If all that clears be aware the wheel will raise the front end about an inch give or take and you will have to space your front fender up to clear the wheel. Good luck on your project.
Old Apr 24, 2020 | 11:21 AM
shattered151
Awesome thanks, I'll check as soon as I can. Do you know how I can add rake as to move the tire forward so not to have a clearance issue? And/or do you know how I can lower these forks?
Old Apr 25, 2020 | 10:09 AM
Big Mule's Avatar
Big Mule
You can lower the forks by ordering a set of Progressive Monotubes. I think they have a 2" lower than stock set. They have them at JP Cycles, Dennis Kirk, and maybe DK Custom sells them.
Old Apr 25, 2020 | 12:27 PM
shattered151
Really? Was told it would probably have to be a custom job. A kit makes it easy enough.
Old Apr 25, 2020 | 12:35 PM
rquest's Avatar
rquest
But as another poster mentioned...This will bring a taller tire even closer to your frame and bottom tree and a lot of negative trail and loss of suspension. I would suggest looking for raked trees.
Old Apr 25, 2020 | 12:40 PM
shattered151
Lol, yeah. Those are pretty much non existent. I've called EVERYBODY I can think of over the past few days. Only options are see how this fits and try and lower it. Or get a new front end completely. There are custom rakes trees out there but not for that HD inverted fork. Nothing for a 52mm. Hopefully an inch doesn't make that much a difference. I see people go from 19 to 21 and all the time with not much an issue. Just hoping it can be done. Really don't wanna drop another 1500 bucks for a front end.
wildbill71232
May 26, 2014 01:32 PM
trainwrek1
Feb 3, 2014 06:51 AM
Towboatcap10
May 2, 2013 03:28 PM
jcallesano
Jul 27, 2010 11:44 AM
thomkat54
Apr 19, 2008 09:53 PM
