Odometer - Not working
Old Jun 1, 2020 | 08:58 PM
bosbury1's Avatar
bosbury1
Switched low and hi beams on no difference in the odometer LED.
Old Jun 1, 2020 | 09:30 PM
im's Avatar
im
What electrical item is not direct from factory since new?
Have you installed some kind of LED head light?
Since bike is 2007 it uses CanBus communication and that could cause an error if something electrical was removed and changed to another aftermarket electrical product.
Old Jun 1, 2020 | 10:25 PM
bosbury1's Avatar
bosbury1
Front light is Custom Dynamics installed in 2013. Checked all the lights they work brake light fine. Stumped. Nobody has seen those codes? No changes to the bike in the last two years.
Old Jun 1, 2020 | 10:41 PM
im's Avatar
im
Consider disconnect of head light and then disconnect negative battery cable.
I will take a guess that you have run switch on OFF when power is removed and then re-applied with head light disconnected.
Perhaps you have the old bulb available for head light socket?
Old Jun 1, 2020 | 10:54 PM
Bone Doc's Avatar
Bone Doc
I thought Harley began using CanBus wiring in 2011. I could be wrong.
Old Jun 1, 2020 | 11:15 PM
im's Avatar
im
You are correct and i was wrong.
Just guessing at this point.
Almost reads like speedometer is trying to signal a problem.
Also looks like someone opened the speedometer.
Hopefully they get it resolved.
Old Jun 2, 2020 | 12:30 PM
bosbury1's Avatar
bosbury1
Took the bike to the dealer today they are not familiar with the code "No LHL". They called Harley Milwaukee and opened a ticket to determine what the code is. I have diagnostic appointment this Saturday at 3:30 to determine the issue. Will report back when I get more information.
Old Jun 4, 2020 | 12:33 PM
bosbury1's Avatar
bosbury1
Dealer contacted me today the code means the speedometer/Odometer is bad. Will have to replace. Thank you.
Old Jun 4, 2020 | 04:16 PM
im's Avatar
im
Unfortunate.
Hopefully a replacement unit can be located.
Old Jun 4, 2020 | 04:28 PM
Jackie Paper's Avatar
Jackie Paper
Unfortunate.
Fish shows it available at $250.
glv1@comcast.net
Aug 15, 2017 01:20 PM
Richie620
Mar 17, 2017 02:09 PM
amanso
Aug 7, 2013 02:02 PM
Drbukk06
May 13, 2011 10:04 AM
Beercan321
Nov 9, 2009 02:14 PM
