Strange speedometer issue
Old Nov 9, 2009 | 01:25 PM
Beercan321's Avatar
Beercan321
Default Strange speedometer issue
I have strange issue with my speedometer that is driving me crazy. I have a combination speedometer / tachometer on my Road King (74549-04). The other day the speedometer, tachometer and odometer stopped working. The unit is getting power as the alarm and engine lights are on. I checked all the wires and connections. There is juice getting to the speedo yet its not working. I did some research and read that this problem could be caused by a bad speed sensor. I replaced it but I still have the problem. I’ve never heard of a speedometer unit going bad before. I don’t want to replace it until I know for sure that the speedo is bad. Does anyone have an idea as to what the problem might be or have had a similar problem? It worked one day and just stopped working the next. I’m baffled.
Old Nov 9, 2009 | 02:02 PM
cmhfguy's Avatar
cmhfguy
Do your turn signals still self cancel, or do they stay on? If they stay on, then you may have another faulty speed sensor. The symptoms you have described as well as the turn signals not canceling usually relate to the speed sensor. Double check your connections and make sure there are no wires pinched for the new sensor.
Old Nov 9, 2009 | 02:14 PM
Beercan321's Avatar
Beercan321
The turn signals work fine. I'm just hoping I'm overlooking something and the speedo unit isn't bad.
tmilo1000
Oct 15, 2018 11:10 AM
harleyfiremedic
Jul 15, 2013 11:39 AM
indy boy
Jul 24, 2010 03:34 PM
jasle
Electrical/Lighting/Alarm
Jul 19, 2009 07:24 PM
JRenegade13
Oct 25, 2007 06:27 PM
